WJ Front Upper Control Arm Bushings...Moog Part #? - Page 3 - JeepForum.com
post #31 of 36 Old 12-11-2012, 06:27 PM
steveo358
I talked to advance on these 2 bushings, he put them together and said that the inside sleee is different on them. said the 3128 has a larger hole. I may get both and have on hand, and send the other one back wwhen I figure out which is the correct one.
steveo358 is offline
post #32 of 36 Old 12-12-2012, 09:17 AM Thread Starter
Fireball027
The moog number I gave fit the factory bolts with very little play.
If the hole is bigger on the other one it may cause noise as the bolt can move around. However take a look at the as the bushing may have a bigger center hole but could have metal bumps inside the hole to center the bolt (just like the ones IRO uses in there upper arms) and make it the same hole diameter as the other moog number.
Fireball027 is offline
post #33 of 36 Old 12-12-2012, 02:25 PM
greenwj
The Moog 3128 bushing is the same size as the 3166 but has a slightly larger bolt hole. I think it is a half inch instead of metric. The 3128 bushings are quite a bit cheaper but they didn't fit for me. You can press it in fine, but when you put the bolts in they are too loose and you have to press them back out and take the back to the store. Ask me how I know...
For me the 3166 was the correct bushing for all 4 upper control arm bushings. The control arm side are very easy to get out, so IMO there is no need to order the whole control arm to replace just a few bushings. The Axle side are very difficult to remove. Also, I had trouble getting the passenger-axle side in without bending the flimsy little bracket.
I also had a very difficult time tightening the bolts with the weight of the jeep on the suspension. There isn't much room and the bolts on the axle side have the stupid torx (T50) heads. If I were to do it over, I would replace those bolts with regular bolts.
As another side note, the Moog bushings are just reboxed clevite bushings. I think most parts stores all sell the exact same bushing under different names (Napa, Duralast, etc.). It will have CLEVITE embosed right in the rubber, just get the cheapest one they are all the same. Took me forever to find the right part number because no one lists that part for a WJ...
greenwj is offline
post #34 of 36 Old 06-24-2013, 09:50 PM
pkess3
Will the Moog 3166's work for the front lower control arm bushings? Do you know?
pkess3 is offline
post #35 of 36 Old 05-27-2014, 05:20 PM
rrose3000
Yes, Look on Youtube theres a guy there that has handle BleepinJeep entitled "Replace upper control arm bushings" and he shows you how to do the upper fnt control arms by jacken up your Jeep in the front and using a bushing press and a rotary impact wrench (I think you can purchase one at "Harbor Freight") to remove the upper control arm bushings at the axle. Be sure and hit them with plenty of "PB Blaster" penetrant the night before so that it has a chance to work in there. It looks like he jacks up the front of the vehicle as high as he can get it, he even uses a 2 foot long 4x4 block of wood under the front bumper to raise his Jeep even higher. As with all bushings once you get them in be sure to compress the suspension so that when you tighten them they are not under a constant twist which will wear them out in under 20k miles. Also use good bushings from Mopar, Moog "Problem Solver Line" or Raybestos Professional grade because you get what you pay for....
Good Luck
rrose3000 is offline
post #36 of 36 Old 05-28-2014, 08:39 AM
WXman
Oreilly's lists a HD poly bushing kit for the front of these Jeeps made by Energy Suspension. Since everybody likes the poly bushings for the track bar, I wonder how they would work for the control arms?
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
How Hard To Replace Rear Upper Control Arm Bushings jtsjeep99 WJ Grand Cherokee Forum 61 05-10-2015 08:45 AM
Second set of rear upper control arm bushings mattmc74 WJ Grand Cherokee Forum 7 05-31-2011 06:56 PM
Confirming Upper Front Control Arm Bushings WiCkeDuDe WJ Grand Cherokee Forum 7 05-28-2011 03:58 PM
Upper control arm bushings, front and rear sinbad85 WJ Grand Cherokee Forum 5 02-09-2011 03:48 PM
WJ Rear Upper Control Arm Bushings Bubba3200 WJ Grand Cherokee Forum 27 10-17-2010 07:55 PM
