WJ Front pinion yoke replacement - JeepForum.com
post #1 of 3 Old 05-03-2013, 09:08 PM Thread Starter
jclaudii
Wj WJ Front pinion yoke replacement
After hoping I'll get lucky in junkyards and craigslist I have came up empty finding pretty much any jeep that is willing to sell just the yoke. Most want to sell the whole drive line intact. So I have found this website, http://www.superioraxlegear.com/spic...1-p-15257.html and it may be the correct one, even though it does not specify. I am at least 98% sure that the tj and zj and WJ all share the same dana 30 center section. Same gears are able to be swapped around to any of those models. But when I search around and see that it don't fit a WJ, it gets me to wondering if I should drop 50 bucks or so.
I want to go ahead and get the front diff swapped out as I think I can find a drive shaft locally that can fit, but it helps to have all the right parts in place to test fit before one buys.
The only other model I see is http://www.superioraxlegear.com/spic...a-p-15253.html but seems to fit the older dana 30 and 44's.
Thanks for your help.
jclaudii is offline
post #2 of 3 Old 05-03-2013, 09:26 PM
perfeng702
IRO has them for $50. u-bolt version.
http://www.ironrockoffroad.com/Merch...egory_Code=PFW
I had a local driveline shop do mine.
1999 WJ 4.7, 242HD, IRO 4" Long Arm, IRO Adj Track Bar, JKS BPE, JKS Quick Disco, 15" Cragar D-Window, 32" BFG KM2, V3 Projectors, DDM Tuning 55w 5k HIDs
perfeng702 is offline
post #3 of 3 Old 05-03-2013, 11:56 PM
MuddyWJ
Iron rock and Kolak both have them. Either way you'll get a genuine spicer product. I bought mine from Kolak.
MuddyWJ is offline
