WJ Front hooks. anyone make them besides rustys - JeepForum.com
post #1 of 14 Old 03-16-2010, 02:37 PM Thread Starter
jeeptorino68
1992 XJ Cherokee
any interest in WJ Front hooks. thinking about making some. need opinions
so i got some WJ factory hooks for the front of my parents WJ at the u pull yard, but was thinking i hadnt seen any after market except the rustys.
if i were to design and sell some brackets would anyone be interested, i could try to keep it under 100$ for the pair im sure,
and it could use the standard tow hooks you buy at the tractor supply store or what not.
thoughts.
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #2 of 14 Old 03-16-2010, 02:41 PM
Apollo21
you would have to make them strong i've bent my factory hooks towing a new Frontier that got high centered
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #3 of 14 Old 03-16-2010, 02:58 PM Thread Starter
jeeptorino68
1992 XJ Cherokee
i was thinking 1/4 inch metal. or 3/16
___
that shape for the passenger side
where the top bolts to the "frame" and extends over to use another bolt like the factory ones do, and the angled piece would be a gusset.
what part bent on your factory brackets?
all grade 8 hardware also.
Kyle
post #4 of 14 Old 03-16-2010, 03:12 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Yeah, better make them super strong. I have Rusty's hooks and bent them the first time I used them, pulling my buddies WJ from a little mud hole. Not deep, he just couldnt get any traction on it. That alone was enough to bend them.
~James
ezflip is offline
post #5 of 14 Old 03-16-2010, 03:15 PM Thread Starter
jeeptorino68
1992 XJ Cherokee
can you describe how/ where they bent? this way i know how to make these stronger
Kyle
post #6 of 14 Old 03-16-2010, 03:20 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Since they sit sideways, it bent the drop bracket. (The red circled part)
~James
ezflip is offline
post #7 of 14 Old 03-16-2010, 03:23 PM Thread Starter
jeeptorino68
1992 XJ Cherokee
ok, so i was kind of thinking along the same lines as that, but with a triangular support behind where the hook goes on. which should be enough to keep it straight.
Kyle
post #8 of 14 Old 03-16-2010, 03:26 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
They do have trusses that you cant see from that pic. I just pulled that pic off there site. Actually, now that I look at it, that bracket in the pic doesnt look anything like mine. Mine have a triangle piece on each side. But still bent.
~James
ezflip is offline
post #9 of 14 Old 03-16-2010, 03:34 PM Thread Starter
jeeptorino68
1992 XJ Cherokee
ok ill think on this
Kyle
post #10 of 14 Old 03-16-2010, 04:09 PM
trailblaze
trailblaze's Avatar
if stock hooks bend under a light load..... it questions whether or not the WJ was ever meant to be off road.
rusty's and stock are the only two i've seen.
Matt
trailblaze is offline
post #11 of 14 Old 03-16-2010, 04:40 PM
Apollo21
my stock ones bent at the drop bracket too but the oem bracket looks stronger than the rusty's one
SOLD
Apollo21 is offline
post #12 of 14 Old 03-16-2010, 06:27 PM
straty1987
the stock wj front hooks use grade 10.9 bolts.
i understand if you use thicker metal to make it and stronger bolts to hole it.
but do you think you can find more room to fit the bigger brackets, bolts, and hooks?
alos teh stock ones can only handle 5,500 pounds or 1.5 times the vehicles GVWR of the WJ. and i think you cant get any better then thank since your mounting it on the frame
the hooks are only meant for recover and not towing, that might be why they bent
straty1987 is offline
post #13 of 14 Old 03-16-2010, 07:32 PM Thread Starter
jeeptorino68
1992 XJ Cherokee
the guy talking about towing the frontier meant recovering, it was high centered, so he was using the hooks as intended.
Kyle
post #14 of 14 Old 03-16-2010, 09:38 PM
SplitNail
I think WJ's were made for pulling bundles of fire wood back to camp. HAHA Rofl.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
Has anyone ever used the Rustys Tow Hooks? G-Wagon00 ZJ Grand Cherokee Forum 25 10-14-2008 02:26 PM
Rustys XJ front long arms work for a ZJ? CLNinja ZJ Grand Cherokee Forum 6 01-15-2008 11:05 AM
rustys front LA rustycherokee18 ZJ Grand Cherokee Forum 1 12-14-2007 07:42 AM
rustys offroad front lca's bryans 86 ZJ Grand Cherokee Forum 6 04-22-2006 04:36 PM
ZJ Front tow hooks.. -Joe- ZJ Grand Cherokee Forum 28 04-08-2006 11:22 AM
