WJ front bump stop ideas???? - JeepForum.com
post #1 of 9 Old 06-21-2010, 07:55 PM Thread Starter
Atlas92
1989 MJ Comanche
My front bump stop bolts broke off when I was in the process of putting on my lift. I just left it there and put on rest of my lift. Now I need some bump stops so my 35s dont get into my fenders. I need about a 6" or 7" bump stop. How and where should I do it??? Thanks for any ideas.
1989 MJ 4.0L/AX15/NP231
HP30/8.8/4.10s
Atlas92 is offline
post #2 of 9 Old 06-22-2010, 03:05 PM Thread Starter
Atlas92
1989 MJ Comanche
Can a bump stop be put inside the coil like the rear?
HP30/8.8/4.10s
Atlas92 is offline
post #3 of 9 Old 06-22-2010, 04:12 PM
nierace
nierace's Avatar
2003 WJ
Bump stop within the coil would be better, but the problem is they're so long in the front.
I'd try one of the ez-out kits where you drill out the hole then use a reverse bit to get the bolt out. Combine that with heat and you should be able to get em, theres a good bit of space there to work.
The other option is to just weld the bump stops on if you have a buddy...
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #4 of 9 Old 06-22-2010, 08:22 PM Thread Starter
Atlas92
1989 MJ Comanche
I dont think an ez-out will work. the bolts would start comming out, then seized up, then broke. Im not a big fan of welding them because I will be redoing them when go with a little more lift. something like a IRO coil retainer from the top, then a little spacer with something soft comming up from the bottom
HP30/8.8/4.10s
Atlas92 is offline
post #5 of 9 Old 06-22-2010, 08:30 PM
tsconver
2003 WJ
drill out the whole nut and weld some new ones in.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #6 of 9 Old 06-22-2010, 08:49 PM Thread Starter
Atlas92
1989 MJ Comanche
another issue is with 6" and short arms that are adjusted out a little, I dont think that the stock location would be far enough forward with it flexed.
HP30/8.8/4.10s
Atlas92 is offline
post #7 of 9 Old 06-22-2010, 08:58 PM Thread Starter
Atlas92
1989 MJ Comanche
OK, i just went out and looked it over and I got an idea. Ill take some 1/4" steel, drill and tap it, (so then Ill be able to move it where ever I need it) then weld it to the frame.
HP30/8.8/4.10s
Atlas92 is offline
post #8 of 9 Old 06-22-2010, 10:24 PM
StrokedWJ
StrokedWJ's Avatar
I extended my front bumpstops with a piece of boxed steel. I think it was 4x2x.25. You could weld the steel to the uniframe and then just drill 2 holes and bolt the oem bumpstop to it.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #9 of 9 Old 06-23-2010, 01:23 PM Thread Starter
Atlas92
1989 MJ Comanche
I like that idea. Ill get something done this weekend and get some pics of what I do.
HP30/8.8/4.10s
Atlas92 is offline
Front Bump Stop Bolt Help RingRingRing ZJ Grand Cherokee Forum 4 03-13-2009 04:48 PM
dumb question, front bump stop removal Dayzz ZJ Grand Cherokee Forum 6 01-25-2009 09:53 PM
WJ: how do you add bump stop to the front? MEinSoCal ZJ Grand Cherokee Forum 7 09-01-2008 09:43 PM
Front bump stop extensions 97zjjeeper ZJ Grand Cherokee Forum 8 05-19-2008 12:00 PM
Bump Go !!!, (Opposite of stop bump) madmarchhare ZJ Grand Cherokee Forum 7 08-25-2006 07:04 PM
