WJ - Front axle loose, clunky Pls read - detailed - Search Completed :-) - JeepForum.com
post #1 of 21 Old 10-28-2009, 07:57 AM Thread Starter
swirls
I searched!
Let me start by saying thank you for reading.
WJ Details:
Tires- 31.5
Lift-KOR BB with Up Country DT8000 Shocks (hub center to fender 21" = 3" lift)
Track Bar- Stock with no axle side hole issues
Transfer case - Select trac
Issue/s:
While is 2 wheel drive the "front end" seems loose (not death wobble, but bump steer) if I put it in 4x4 fulltime everything seems to tighten up... BUT issue 2 is still there.
Issue 2
really issue 1 - Front right, passenger side suspension travel is very clunky. I really do not want to start replacing things and spend money without fixing the issue. Let me explain... Oh all TREs replaced
at times if i travel slowly, rolling over speed bumps I will here a clunk on the down travel... This sound also is prevelate while driving down my friends driveway on his farm... dirt, gravel washboardy
And on the beach
just clunkiness on the downtravel
Thoughts
Everything is tight or appears tight
No tire movement 12 and 6 or 9 and 3
LCAs?
UCAs?
I am looking for the experts to help out. I can take some flaming to make it a good tread
Thanks
swirls is offline
post #2 of 21 Old 10-28-2009, 08:48 AM
99avant
What happens in Part time 4x4? Are you sure this really fixes the issue??
Get under there and see if anything is tight. Grab the control arms and wiggle them. See if you can move your tie rod and drag link more than usual. Is your trac bar tight with good bushings?
I do this weekly.. just something to deal with on a lifted jeep.
I would consider an adjustable tracbar.. My axle was not centered with the UC + BB combination.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #3 of 21 Old 10-28-2009, 09:02 AM Thread Starter
swirls
Originally Posted by 99avant View Post
Give it time... We all have lives besides yours and our jeeps.. at least we should.
Agreed it was more a bump than anger
To answer the other questions
I cannot move anything I will throw out my back before anything moves.
Now the track bar is interesting. it is stock and my axle is not centered.
4x4 doesnt 'fix it' it does feel a bit tighter up there. bump steer goes away
swirls is offline
post #4 of 21 Old 10-28-2009, 09:18 AM
Yardman Harry
O
Yardman Harry's Avatar
What about your sway bar bushings? Those make a nice mysterious bump/clunk when they are worn. At first glance they may look aok, but you have to inspect them carefully.
Interesting about 4x4 though... not sure what to think about that
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #5 of 21 Old 10-28-2009, 09:29 AM
WJ04
couple of things:
1st get a HD sterring stabilizer to handle the bigger tires, that was the cause of my bump steer.
2nd at 3'' you need the following: adjustable track bar, extended links ,and shocks for a 3'' lift. if you bought shocks for a 2'' lift they might be to short, most of the time shocks that say 0-2'' lift are about the same lengh as stock.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #6 of 21 Old 10-28-2009, 09:59 AM
99avant
Bump steer can also come with a loose steering box. Adjusting it made a world of difference for me-
*edit- I replaced all front control arm bushings, front bar links, tre's, have good shocks. Still had bump steer till I tightened the steering box.
99avant is offline
post #7 of 21 Old 10-28-2009, 10:00 AM Thread Starter
swirls
Originally Posted by WJ04 View Post
couple of things:
OME HD Stablizer installed - Still have bump steer
Shocks are: 8000 Pre-Runner
Extended links for the front - Is that really needed? Track Bar is on order
Extended Collapsed
Length Length
8282 24.5 14.5 FRONT
8333 26.5 15.5 REAR
swirls is offline
post #8 of 21 Old 10-28-2009, 11:03 AM
CrazyIvan888
Could the clunking be a broken coil spring? I would check the spring, most commonly they will break at the top or bottom rather than in the middle anywhere.
2 cents spent.
CI888
CrazyIvan888 is offline
post #9 of 21 Old 10-28-2009, 01:24 PM Thread Starter
swirls
Anyone else have good advise?
All that have posted thank you
I will check coils
I will check Steering Box etc
thanks
swirls is offline
post #10 of 21 Old 11-06-2009, 08:21 AM Thread Starter
swirls
I will check coils
thanks
Checked above and installed adjustable tracker bar..
This morning backing our of my gargage and tapped the brakes the passenger side clunked... Caliper shift? Control Arms?
Thoughts?
swirls is offline
post #11 of 21 Old 11-06-2009, 09:14 AM
Max78
1992 XJ Cherokee
Check upper and lower control arm bushings (or have somone check for you)
Check all ball joints
Maybe check shock? (I got a bad one from Rubicon Express it happens)
Are you sure all TRE’s are torque to spec? maybe one came loose?
Check caliper bolts.
That’s all I can think of at the moment.
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #12 of 21 Old 11-06-2009, 09:17 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Ball Joints would be my guess...I would start checking them. Jack up wheel and put a pry bar (a 2x4, etc...) under the wheel to try and pry it up. Watch the ball joints for movement. IMHO 1/16" is too much movement. Anything more and you're way too much.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #13 of 21 Old 11-06-2009, 12:24 PM Thread Starter
swirls
That would make sense since it happens on the down travel... so probably the upper Ball Joint.
Would a bad ball joint make noise while back then hitting the brake ***clunk***?
Again thanks forum
swirls is offline
post #14 of 21 Old 11-06-2009, 04:46 PM
ArloGuthroJeep
Mr. Hyde!
If you get clunking while braking either check the brake caliper bracket bolts or the Control Arm bolts and bushings (bushings need to have the CA's removed to properly inspect them).
-Ryan
post #15 of 21 Old 11-06-2009, 05:20 PM Thread Starter
swirls
Thats good info...
I do not get the clunk going forward only backing... or rolling backwards and tap brake quickly and firm...i.e back out driveway clunk
or back out of the drive and rolling off the 'ramp curb' (driveway to street transition)
I am thinking it is one of these
CA or Ball Joint
I took off the caliper and reinstalled same noise
UHG - I want to run this into a brick wall - But I love it..its still a baby 113K on the clock
swirls is offline
Read axle problems abe51 ZJ Grand Cherokee Forum 3 07-28-2009 09:47 PM
IRO lift - few q's (yes read faq's/search) sejamis ZJ Grand Cherokee Forum 4 03-17-2009 10:00 PM
axle ? how do u read tag ttavenieriii ZJ Grand Cherokee Forum 25 11-20-2008 11:06 PM
Rear axle hubs are loose? FortCollinsZJ ZJ Grand Cherokee Forum 1 09-26-2007 03:22 PM
Rear right axle seal leak...tried search but can't find blizzboy283 ZJ Grand Cherokee Forum 8 01-25-2006 03:48 PM
