WJ Forum FAQ's *READ THIS BEFORE YOU POST* - JeepForum.com
post #1 of 5 Old 10-16-2009, 01:08 AM Thread Starter
Jones
Consider the following...
Jones's Avatar
INDEX
Frequently Asked Questions
Vehicle Specs
Commonly Used Links
JeepForum.com Frequently Asked Questions
Jones is offline
post #2 of 5 Old 10-16-2009, 01:09 AM Thread Starter
Jones
Jones's Avatar
Frequently Asked Questions / Write-ups
Suspension / Tires
Tire Size vs. Amount of Lift Chart
Common Budget Boost "BB" Questions
What do I need for a 5"+ lift?
Puma's answer to the ZJ front swaybar issue!
WJ Suspension Info thread
What is Death Wobble and How Can I Cure It?
How do I assemble Addco swaybar end links?
Swaybar Endlink Info
Axles / Differentials
How to replace and axle shaft and/or a wheel hub bearing assembly
D44a Aussie Locker Install
Warped Rotors (Front end vibrates when I apply the brakes)
A really Good Gear ratio and transmission calculator
Rebuilding a D44a axle
Regearing Chart
Engine / Transmission / Transfercase
46RE Rebuild
5.2 to 5.9 Swap
I just pulled the check engine code, what does it mean?
There is oil in my breather.
4.0L Oil Filter Adapter O-ring replacement.
Taurus E-Fan Conversion
NP249, NV249 Viscous Coupling
NP249 TO NP242 (or 231) SWAP
ZJ Transmission Band Adjustment
Swapping a 42RE for an AX-15
WJ 247 -> 242 HD Swap
ZJ Fuse Panel Diagram / Power Distribution Center / PDC
I just regeared or changed tire size on my ZJ, what speedometer gear do I need now?
How do I replace the front crankshaft oil seal?
How do I clean the IAC (Idle Air Control) valve?
Superlift Truespeed
Solution to the long starting problem
4.0 Engine Misfires
Driveshaft Specs
Electrical
http://www.jeepforum.com/forum/f197/...-98-zj-767865/
My backup lights don't work or work intermittently.
Power windows/locks stop working
How Can I wire Fog lights up in a ZJ that didn't already have factory Fogs?
Programming 93-95 ZJ's IR Keyless Entry Remotes
Climate Control Diagnostic Mode
Miscellaneous
Passenger Floor Board Wet?
Swampy Bypass fuel pump system conversion
ZJ Fender Trimming
Grand Cherokee Most Common Mods
Commonly Used Acronyms
How Do I Reset the Miles to Service Display?
What are the Technical Service Bulletins for my Jeep?
Where can I request my buildsheet?
License Plate Mount for Roller Fairleads
Custom Bumpers
Fluids for the Grand Cherokee
Fix that sagging door from 95GC
Overhead console install on 93-95 ZJs
Replacing the lift struts
How to replace a ZJ sunroof seal
Cold passenger/Hot driver and vice-versa (WJ blend doors)
http://www.jeepforum.com/forum/f13/d...p-pics-884932/
How to remove cladding on 93-98 ZJ's
Jones is offline
post #3 of 5 Old 10-16-2009, 01:10 AM Thread Starter
Jones
Jones's Avatar
Vehicle Specs
ZJ/WJ trim models
Listed from lowest priced to highest.
1993- Base, Laredo, Grand Wagoneer, Limited,
1994- SE, Laredo, Limited
1995- SE, Laredo, Limited, Orvis Limited
1996- Laredo, Limited
1997- Laredo, Tsi, Limited
1998- Laredo, Tsi, Limited, 5.9 Limited
1999- Laredo, Limited
2000- Laredo, Limited
2001- Laredo, Limited
2002- Sport, Laredo, Special Edition, Limited, Overland
2003- Laredo, Limited, Overland
2004- Laredo, Special Edition, Columbia/Freedom Edition, Limited, Overland
Updates:
1994 - Limited gets rear disc brakes instead of drums used on all 1993, and 1994 Laredo Models.
1995- 2WD is offered in Limited trim, disc brakes for all trim models.
1996- 2WD is offered in both Laredo and Limited, 6 and 8 cylinder models.
1998- 5.9 Limited is offered, and only has a single year of production.
1999- 4.7 Liter V8 takes over the 5.2 V8 spot.
2002- Quadra-Drive is offered as an AWD system - 4.7 gets limited production High-Output (HO) version.
Jeep ZJ Produced from 1993-1995
Exterior Dimensions:
Length: 176.7 in. Width: 69.2 in.
Height: 64.9 in. Wheel Base: 105.9 in.
Ground Clearance: 8.2 in. Curb Weight: 3574 lbs
Interior Dimensions:
Front Head Room: 39 in. Front Hip Room: 56.9 in.
Front Shoulder Room: 58.2 in. Rear Head Room: 39 in.
Rear Shoulder Room: 57.6 in. Rear Hip Room: 49.3 in.
Front Leg Room: 40.8 in. Rear Leg Room: 35.7 in.
Luggage Capacity: 40.1 cu. ft. Maximum Cargo Capacity: 80 cu. ft.
Maximum Seating: 5
Performance:
Base Number of Cylinders: 6 Base Engine Size: 4 liters
Base Engine Type: Inline 6 Horsepower: 190 hp
Max Horsepower: 4750 rpm Torque: 225 ft-lbs.
Max Torque: 4000 rpm Maximum Payload: 1150 lbs.
Maximum Towing Capacity: 5000 lbs. Drive Type: RWD
Turning Circle: 36.6 ft.
Optional Engine - 5.2 MPI V8 (MPI stands for Multi-Port Injection)
Horsepower:220
Fuel Data:
Fuel Tank Capacity: 23 gal.
EPA Mileage Estimates: (City/Highway) for 6cyl
Manual: 16 mpg / 21 mpg Automatic: : 15 mpg / 20 mpg
Range in Miles: (City/Highway)
Automatic: 345 mi. / 460 mi. Manual: 368 mi. / 483 mi.
1996-98 ZJ Dimension changes - (If not shown, it did not change)
Exterior:
Length: 177.2 in. Width: 69.3 in.
Ground Clearance: 7.7 in. Curb Weight: 3926 lbs.
Interior:
Front Head Room: 38.9 in. Front Hip Room: 56.7 in.
Front Shoulder Room: 59.2 in. Rear Head Room: 39 in.
Front Leg Room: 40.9 in. Rear Leg Room: 35.7 in.
Luggage Capacity: 40.9 cu. ft. Maximum Cargo Capacity: 79 cu. ft.
Maximum Seating: 5
Performance for 6 cyl:
Acceleration (0-60 mph): 8.6 sec. Braking Distance: 138 ft.
Road Holding Index: .75 g Base Number of Cylinders: 6
Base Engine Size: 4 liters Base Engine Type: Inline 6
Horsepower: 185 hp Max Horsepower: 4600 rpm
Torque: 220 ft-lbs. Max Torque: 2400 rpm
Maximum Payload: 1150 lbs. Turning Circle: 37.5 ft.
1998 5.9 Limited Performance: (Available only in 1998)
Performance:
Acceleration (0-60 mph): 7.1 sec. Braking Distance: 135 ft.
Road Holding Index: .75 g Base Number of Cylinders: 8
Base Engine Size: 5.9 liters Base Engine Type: V8
Horsepower: 245 hp Max Horsepower: 4000 rpm
Torque: 345 ft-lbs. Max Torque: 3200 rpm
Maximum Payload: 1150 lbs. Maximum Towing Capacity: 5000 lbs.
Drive Type: 4WD Turning Circle: 37.2 ft.
Fuel Data
Automatic: : 13 mpg / 16 mpg
Automatic: 299 mi. / 368 mi.
1999-2004 Grand Cherokee - the WJ
Exterior
Length: 181.5 in. Width: 72.3 in.
Height: 69.4 in. Wheel Base: 105.9 in.
Ground Clearance: 9.1 in. Curb Weight: 3879 lbs.
Interior
Front Head Room: 39.7 in. Front Shoulder Room: 58.9 in.
Rear Head Room: 39.5 in. Rear Shoulder Room: 57.8 in.
Front Leg Room: 41.4 in. Rear Leg Room: 35.3 in.
Luggage Capacity: 39 cu. ft. Maximum Cargo Capacity: 72 cu. ft.
Maximum Seating: 5
Performance
Acceleration (0-60 mph): 9.1 sec. Braking Distance: 145 ft.
Road Holding Index: .73 g Base Number of Cylinders: 6
Horsepower: 195 hp Max Horsepower: 4600 rpm
Torque: 230 ft-lbs. Max Torque: 2400 rpm
Maximum Towing Capacity: 2000 lbs. Optional 5000 lbs with Tow package
Optional Engines:
4.7 "Power-Tech Engine" 16-valve V8
Horsepower: 235 @ 4800 rpm
Torque: 295 ft/lbs @ 3200 rpm
Fuel Data
Fuel Tank Capacity: 20.5 gal.
Automatic: : 16 mpg / 21 mpg
Automatic: 328 mi. / 430.5 mi.
ZJ/WJ Axle, Transmission, Transfercase Info
Axles:
1993 to 1995
Standard Package, 4.0L:
Front: Dana 30, 3.55:1 final drive ratio
Rear: Dana 35C, 3.55:1 final drive ratio
Standard Package, 5.2L:
Front: Dana 30, 3.73:1 final drive ratio
Rear: Dana 35C with optional LSD, 3.73:1 final drive ratio
Towing Package, 4.0L and 5.2L:
Early D30s were the Long Pinion variant.
1996 to 1998
Towing Package, 4.0L:
All Packages, 5.2L:
Rear: Dana 44a with optional LSD, 3.73:1 final drive ratio
All Packages, 5.9L:
Rear: Dana 44a with LSD, 3.73:1 final drive ratio
Transfercases:
NOTE: NP stands for New Process, NV stands for New Venture. They switched names in the 90s for an unknown reason, but are the same company.
NP242 used on I6 ZJs and WJs - This is known as SelecTrac NOTE: 93-94 V8 ZJ's had option of the NP242 Selec-Trac t-case.
NP249 used on all V8 ZJs and was optional on 6 cylinder models - This is known as QuadraTrac.
NP 231 used on various "heavy duty" ZJ and WJ V8s - known as Command-Trac
Also in 93-94 NP231 Command Trac was available with the I6's in SE's and Laredo 's.
2002 - Quadra-Trac II introduced as option on V8s- known as Quadra-Drive, this is an AWD system similar to Audis and Subarus.
Transmissions
545RFE 5 spd. automatic transmission used in the 2001 - Current Model Jeep Grand Cherokee 4.7L engines
45RFE: 4 spd. automatic transmission used in 1999 - 2000 Jeep Grand Cherokees with 4.7L engines.
46RE: 4 spd. automatic transmission used in 1998 Jeep Grand Cherokees with 5.9L engines.
44RE: 4 sd. automatic transmission used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines.
42RE: 4 spd. automatic transmission used in 1993 to 2002 Jeep Grand Cherokees with 4.0L engines.
46RH: 4 spd. automatic transmission used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines
AW-4: 4 spd. automatic transmission used in some 1993 Jeep Grand Cherokee's with 4.0L engines.
Jones is offline
post #4 of 5 Old 10-16-2009, 01:10 AM Thread Starter
Jones
Jones's Avatar
Jones is offline
post #5 of 5 Old 10-16-2009, 01:11 AM Thread Starter
Jones
Jones's Avatar
Jones is offline
Closed Thread
axle , backspacing , differential , engine , faq , grand cherokee , lift , suspension , tire , transfercase , transmission , wj , write-ups , zj
