WJ Forum FAQ *READ THIS BEFORE YOU POST* - JeepForum.com
post #1 of 13 Old 12-21-2011, 07:42 AM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
INDEX
JeepForum.com Frequently Asked Questions
Commonly Used Links
Vehicle Specifications
Engine
Transmission
Transfer Case
Axles / Differentials / Driveshafts
Steering
Suspension / Tires
Electrical
General Repair
Build Thread Index
Brian
WJ, WK, CJ5
GraKee99 is offline
post #2 of 13 Old 12-21-2011, 07:53 AM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
JeepForum.com Rules
WJ Grand Cherokee Forum Rules
How do I use the Search Function?
Premium Membership: Avatar, Custom Title, and Enhanced Signature
Brian
WJ, WK, CJ5
GraKee99 is offline
post #3 of 13 Old 12-21-2011, 08:19 AM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
GraKee99 is offline
post #4 of 13 Old 12-21-2011, 08:22 AM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
Model Information
Vehicle Specifications and Dimensions
Engine Information and Specifications
Four Wheel Drive
Brian
WJ, WK, CJ5
GraKee99 is offline
post #5 of 13 Old 12-21-2011, 08:29 AM Thread Starter
GraKee99
Rapist Wit
GraKee99's Avatar
GraKee99 is offline
post #6 of 13 Old 12-12-2014, 10:37 AM
ChrisHager
Administrator
ChrisHager's Avatar
Transmission
42RE Governor Pressure Sensor & Solenoid Write-Up
42RE Snap Ring Repair
The Chrysler 545RFE is One Hell Of A Tough Transmission And Here’s Why
NV3500 5 Speed Swap
Jeep WJ P0702
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #7 of 13 Old 12-12-2014, 10:37 AM
ChrisHager
Administrator
ChrisHager's Avatar
Transfer Case
NP242 Internals
NP242 Rebuild Tutorial
Transfer Case Fluid Change - NV242
247 - 242HD Swap
247 - 231 Swap
231HD Build
ZJ 249 - 242 Swap
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #8 of 13 Old 12-12-2014, 10:37 AM
ChrisHager
Administrator
ChrisHager's Avatar
Axle Identification
WJ Driveshaft Information Page
Drive Shaft Identification
Double Cardan Rebuild
Rezeppa to Double Cardan - IRO Drive Shaft Conversion
Differential Fluid Change
5x5 Wheel Cross Reference Chart
Compatible Jeep Wheels
Warped Rotors (Front end vibrates when I apply the brakes)
Front and Rear Brake Rotor and Pad Removal and Installation
Rear Brake Pad and Rotor Guide (PICS!)
How to replace Ball Joints
How to replace an axle shaft and/or a wheel hub bearing assembly
Front Axle Spring Perch Repair
What? Why do I need a locker? I thought I had 4WD!
D44a Aussie Locker Install
Rebuilding a D44a axle
Differential Setup Information
Gear Ratio and Transmission Calculator
Regearing Chart
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #9 of 13 Old 12-12-2014, 10:48 AM
ChrisHager
Administrator
ChrisHager's Avatar
Steering
How to Center the Steering Wheel
Tie Rod End Replacement (Drag Link)
Tie Rod Ends and Adjusting Sleeves Replacement
Dual Steering Stabilizer Write Up
Steering Box Adjustments - How To Fix your Floppy Steering
Steering Box Re-Seal and Tap for Hydro Assist
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #10 of 13 Old 12-12-2014, 10:48 AM
ChrisHager
Administrator
ChrisHager's Avatar
Suspension / Tires
0" - 2" Lifted WJ Grand Cherokees - Picture Thread
2.5" - 3.5" Lifted WJ Grand Cherokees - Picture Thread
4" - 4.5" Lifted WJ Grand Cherokees - Picture Thread
5"+ Lifted WJ Grand Cherokees - Picture Thread
Suspension Glossary
Common Budget Boost "BB" Questions
The Comprehensive BDS/FatBob's 2" Lift Thread
WJ Suspension Info Thread
12 Things to Know About Lifted Suspension Engineering
Lift Coil Spring Rates
Sway Bar Information
Extending Rear Sway Bar End Links Using Spacers
$8 Sway Bar Link "Rattle" Repair
Death Wobble Info
What is Death Wobble and How Can I Cure It?
What is the largest tire I can run on my WJ without a lift?
What PSI should I set my tires to?
Correlation between Tire Size and MPG - Revealing Math
Tire Size vs. Amount of Lift Chart
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #11 of 13 Old 12-12-2014, 11:16 AM
ChrisHager
Administrator
ChrisHager's Avatar
Electrical
Retrieving Diagnostic Trouble Codes (Key Dance)
WJ Electric Fan/Relay Information
Fan Relay Test
Fan Relay Removal and Replacement
WJ Flasher Repair Picture Guide
Power windows/locks stop working
1999-2004 WJ Driver Door Boot Wiring Fix
LED Mods
Power Inverter Install
Bluetooth Light Switch
Avital 4103LX/DBALL2 Installation Write-Up
Installing Uniden PRO520XL CB into WJ Ash Tray Area
Dual Battery Optima Odyssey in Stock 4.7L Location
Rebuilding an Alternator
SWI-JACK Installation - Retaining Steering Wheel Controls with Aftermarket Bluetooth Head Unit
Philips HIR Headlight Upgrade
HID Retrofit
Quad Light "How To" for European WJ (WG) Owners!
Dorman Heated Pad Install
4.0 Crankshaft Position Sensor Replacement
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #12 of 13 Old 12-12-2014, 11:16 AM
ChrisHager
Administrator
ChrisHager's Avatar
General Repair
Maintenance Information and Schedules
WJ Torque Specs - Complete List
Front Wiper Repair - Fix Your Paranormal Wipers!
Rear Wiper Repair - Refurbishing/Repairing the WJ's Rear Wiper Motor
Window Regulator Replacement (with Video)
Cheap Window Regulator Repair
Seat Motor Repair
Dual Control Blend Door R&R without Dash Removal
Cheap WJ Recirculation Door Fix
Fully Functional Recirculation Door - Glove Box Repair
Factory Hitch Installation
Custom Bumpers
Removing WJ Front Fender Write-Up (Pic Heavy)
WJ Fender Trim
Kolak WJ Exhaust System Install
Cabin Air Filter and Housing Write-Up
Headliner Removal/Re-Surface/Install Write-Up
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #13 of 13 Old 12-23-2014, 12:32 PM
ChrisHager
Administrator
ChrisHager's Avatar
Build Thread Index
311WJ's Build Thread
4x4Jeep's Build Thread
85IrocZ-28's Build Thread: Project Yeti
adavis39's TheUTwj Build Thread
AgitatedPancake's 5 Speed WJ Build
Akrobatiks' Build Thread
alwaysHI's College Build Thread
ArloGuthroJeep's Build Thread
Bama_WJ's Build Thread
Berndog67's 03 1-ton Over(any)land WJ Build Thread
Bigredhawkeye's 2000 WJ Expedition Build Thread
Billzcat1's More-Travelling-Than-Building Build Thread
Black04WJ's "The UTE" Build Thread
Boover's Purp Jeep Build Thread
Braddf's Build Thread
Broadz's Australian '01 WJ Audio Build Thread
ChrisHager's Build Thread
clgielin's Build Thread
DrGrand's Highschool Budget (at least one time it was) WJ Build Thread
drwolcot's 2WD-->4WD Swap Build Thread
ezflip's Build Thread
fasteddy47's "The Money Pit" Build Thread
Fosterjd79's Build Thread
GCJEEPING's Build/Mod Thread - It's A Green Thing
GraKee99's Build Thread
hammered1's "The Family Truckster" Build Thread
Hierotochan's Build Thread - The Hulk!
Jeep01AH's Black 4.7 Build Thread
JerzeyBoyWJ 03 WJ Build Thread
Killallblue's Build Thread
MallCrawlWJ's Rattle Can Special Build Thread
Maximus_Daximus' "Metal Mulisha WJ" Build Thread
MGDWJ's 1-ton/Dana 60s Build Thread
Mighty Thor's Re-Build Thread
Morphine's Grand Cherokee WJ from Germany Build Thread
mrJ's Build Thread
mtnmarc's Build Thread
Mud_Crazy's (Backdoor_Artist) Build Thread
NarnWV's Build Thread
Nightmares' 99 WJ Build Thread
nolimitssjca's Jeep Rehab – One WJ Jeeps Story of Rescue from Neglect
nUcKiNfUtZ's Build Thread
OrvisAM's Teenage Budget Build Thread
PackLiveNC's College Budget Build Thread - 2001 WJ 4.7L
Pete's Build Thread - The Chuck E. Cheese WJ
platinum5.9's 03 WJ LTD Daily Duty/Weekend Warrior Upgrades Thread
Rusty's WJ Overland Build Thread
SaturnICL's The White Whale Build Thread
scparrish's Build Thread
Snobrdrkid's Build/Discussion Thread
SplitNail's Build Thread
TeeJays Expedition Rig
ThaBeefs' 03 Black WJ on 32s Build Thread
Thomahawk's 2000 GC 4.7 Limted QD Jeep in Norway
tsconver's Project Patriot Build Thread
USMCBehrensDVLD's DevilDog Edition Build Thread
veiri86's Parallel Build Thread (2 x WJ's)
WJ_Bowne's Build Thread
wj4play's Build Thread
WJDesertRacer's West Coast Style Build Thread
WJwheelin's JeepZilla Build Thread
wvracer821's Build Thread
yohshua's Build Thread
***If you would like a build thread added to this list, PM a WJ Moderator with the Title and Link to the thread.***
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Closed Thread
WJ Picture Thread ArloGuthroJeep WJ Grand Cherokee Forum 1959 01-29-2017 05:43 PM
A/Cissue 3rd post Am I in the wrong forum? Neal WJ Grand Cherokee Forum 5 09-15-2011 05:51 PM
Alternator field terminals both read full voltage when... JeepManZJ WJ Grand Cherokee Forum 31 05-04-2011 01:51 PM
what shall i do? Please read! XJ57 WJ Grand Cherokee Forum 3 11-15-2010 08:01 PM
WJ Forum FAQ's *READ THIS BEFORE YOU POST* Jones WJ Grand Cherokee Forum 4 10-16-2009 01:11 AM
