WJ: Final fix for power seats. - JeepForum.com
post #1 of 13 Old 11-04-2009, 10:50 PM Thread Starter
iluvtruenos
If you've got a WJ with the motorized seats, then you're probably all too familiar with the broken seat bracket. Get it welded, 300 miles later another one breaks.
After having my seats welded three times, with enough fires and burned material to show for it, I wanted to find an end-all solution to this problem.
This lies in the ZJ seat rail bracket.
To the untrained eye, the ZJ rail is a duplicate of the WJ rail with one advantage: It's 2x as beefy. Instead of a single piece of 1/8" steel to lower, raise, and hold all the g-forces of a 200lb human for 150k miles, the ZJ uses a boxed setup, with 1/8' steel.
Now for the pics:
This is the seat that I have: full-way power with heated leather.
I got a seat rail from a full-power, non-heated cloth 1996 Laredo ZJ. It had the same plastic and buttons on the side as did mine.
The offender:
ZJ seat rail. From a 1996 ZJ, full power. (I don't know if the non-powered reclining ones are the same, that's going to have to be discovered, but most lilkely yes)
You'll notice it comes with the seat belt clip. Unbolt it, and discard/keep it. The WJ's is mounted to the transmission hump.
Next, unbolt the four 1/2" or 13mm bolts. I highly suggest buying a ratcheting wrench just for this purpose. My shallow well craftsmans were too tall, and using a regular box-end wrench would take next to forever.
Make sure to unclip the wiring harness from the seat rails too.
After unbolting, this is what you should have:
ZJ on right, WJ on left.
Looks easy, right? Just rebolt the ZJ rail, and all is well, right?
WRONG!!!
Chrysler decided "Hey, let's mess with anyone that tries to work on our stuff, since it looks like it would fit, but really doesn't"
The part that attaches to the actual floor of the car has to be reused from the WJ rails. The ZJ ones are 1/8" of an inch too close together.
Unbolt this bolt:
And slide the rails from the WJ onto the ZJ.
Now you have a bomb-proof motorized mechanism that is sturdy as hell.
***NOTE: These are motorized seats, meaning that if you get them at a junkyard, there is no guarantee that you will be able to access the back two bolts. Bring a 12v or higher drill battery, and use that to move the seat back and forth.
Hey mods, since I can be a productive member of JF, can I be let back into General Discussion? Please, pretty please, with a solid axle on top?
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #2 of 13 Old 11-06-2009, 12:29 PM Thread Starter
iluvtruenos
bump damnit.
post #3 of 13 Old 11-06-2009, 01:06 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
I must say you were pretty determined to get your seat working without having to buy a new one, and without having me weld it again!
I will be doing this to both my WJs.
Nice work!!!
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #4 of 13 Old 11-07-2009, 02:43 AM Thread Starter
iluvtruenos
Heh, true, your beer a weld prices are getting kinda stiff nowadays. Especially with the economy. You know, fuel economy.
post #5 of 13 Old 03-02-2010, 09:39 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
**I have some important info to add..
This info is about doing the seat frame mod/upgrade to a LIMITED model.
So if you have a WJ Limited, you need to use a seat frame from a Limited ZJ, to ensure the memory seat buttons will still work, as the Laredo motors dont have a spot to connect the sensor wires.
post #6 of 13 Old 12-01-2010, 09:07 PM
U2Fans
iluvtruenos... Thanks for this thread. I just had a great idea.
Junkyard power leather seats with heat. They require a different harnesses (most likely) and a matching switch. I have a feeling that my seat will be broken again before I get there though. Good info, thanks.
The "Other" Voice of Reason
Who's got some sliders they want to sell me???
U2Fans is offline
post #7 of 13 Old 12-02-2010, 12:03 AM Thread Starter
iluvtruenos
Nope, harnesses are the same. At least the plugs are.
I've noticed this:
ZJ Laredo: Same plug as Limited, but had 3-4 less wires. The seat was cloth/non heated, but had same plug as leather/heated.
ZJ Limited: Same plug as Laredo, but 3-4 more wires. The model I saw DID NOT have heated seats, but did have memory. Same plug as heated/leather/memory.
post #8 of 13 Old 12-02-2010, 12:13 AM
nlynd1978
2006 XK Commander
So, whos car did you steal those out of?
06 Commander Limited,4.7,130k
01 GC Limited,QD-II,4.0,236k-sold
99 GC Laredo,QT-II,4.7,96k-Sold
nlynd1978 is offline
post #9 of 13 Old 12-02-2010, 12:29 AM
U2Fans
My wife just wants a heated ***... and I wanna give it to her.
U2Fans is offline
post #10 of 13 Old 06-19-2015, 02:12 PM
pauldustin91
2010 KK Liberty
I know this post is years old but I'm dealing with the exact same problem and not being able to find a solid wj seat bracket. Do the seat movement wires from a wj match up to a zj floor bracket (and motors) without splicing
pauldustin91 is offline
post #11 of 13 Old 06-19-2015, 07:57 PM
stone white 99
Anyone on the ZJ to WJ motor connectors? as far as the bracket goes though
There is a bulletproof aftermarket one that im going to get someday
http://www.jeepseatbracket.com/colle...eat-repair-kit
I do understand people wanting to do this on the cheap but it not my style im into long term solutions.
The other part mentioned on this thread is the seat heater. I guess dorman makes an aftermarket heating element?
stone white 99 is offline
post #12 of 13 Old 06-26-2015, 07:30 PM
pauldustin91
2010 KK Liberty
Yeah but it's 200$ 200$ could go somewhere else much better. Like on board air
post #13 of 13 Old 06-27-2015, 08:34 PM
UZI4U
I went this route because getting another seat from the wrecking yard was pretty close to the same price (they won't separate frames from seats). The aftermarket frame is built like a brick $#!+ house and will never break. If it does, it's a ZJ frame to the rescue.
MCLMM
UZI4U is offline
does a wj with manual seats have the harness for power seats? Meanmatty ZJ Grand Cherokee Forum 0 02-08-2010 07:04 PM
Cruise control, power seats, power locks, don't work. Metzroth ZJ Grand Cherokee Forum 2 01-17-2010 10:05 PM
Possible to swap over seat brackets from manual seats to a set of power seats? fmalgapo ZJ Grand Cherokee Forum 3 11-11-2009 05:45 PM
Installing 98 ZJ heated seats in a 93 with no power seats aaron7 ZJ Grand Cherokee Forum 4 12-28-2008 11:47 AM
Replacing Front Seats with Power Seats? dpierson ZJ Grand Cherokee Forum 1 06-02-2004 12:40 PM
