WJ FAQ - Help contribute here! - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > WJ FAQ - Help contribute here!
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 12-08-2011, 08:31 AM   #61
sxr951
Wj
I have seen on you tube that some head light housings have the same bulb insert but teh hid bulbs are to long to fit! rendering the housing useless for HID. i dont no what gen it was..
Originally Posted by Aathos View Post
Projector Headlights and HIDs
There are many people selling projector headlight housings for WJs, but there are only three styles of projector headlights for WJs. All of these styles are available in chrome, black or smoked finishes.
The Gen I has three LEDs in upper corner near the grill.
The Gen II has a row of five oval lights along the bottom.
The Gen III looks most like stock with a bar along the bottom and 3 LEDs for the side turn signals.
There is no factory connection for the halos, but they can be spliced into the parking lights, turn signals, or fog lights.
HIDs should only be put in projector housings so that you don't blind on-coming cars. Also, only put them in the low beams. The warm up time makes them unsuitable for high beams. 6000K bulbs are generally recommended, though some people like 5000K bulbs. There are also many vedors for HID kits, but DDM Tuning is a popular source.
sxr951 is offline   Reply With Quote
Unread 12-08-2011, 01:13 PM   #62
ChrisHager
ChrisHager's Avatar
It is located in the Suspension Info sticky.
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
Hers: 2000 TJ
ChrisHager's 'Grilled' Thread
WJ Torque Specs
Originally Posted by tommyooooooh View Post
But ChrisHager makes me want to poor water on a burning bucket of gasoline now just out of curiosity.
Originally Posted by billzcat1 View Post
The latest lift kit from Rough Country? :D
Originally Posted by Jeeples View Post
Your symptoms sounds just like what it does when it's not doing what it should because of how it is.
ChrisHager is offline   Reply With Quote
Unread 12-08-2011, 01:38 PM   #63
blazepsi
INFORMATIVE VIDEO:
Enjoy
Differential Side Gear Backlash Measurement
Differential Ring and Pinion Gear Setup
blazepsi is offline   Reply With Quote
Unread 01-09-2012, 02:40 PM   #64
BandGauto
1999 -200? If your front drive shaft boot (the one from your transfer case to the front diffy) is torn but your CV joint is in otherwise good condition and you just want to replace the boot without spending $200 on a CV joint rebuild kit, NAPA has a boot that fits perfectly. Part #686-2332. It looks different than the original one but it works. Cost $19.
BandGauto is offline   Reply With Quote
Unread 03-19-2012, 02:26 PM   #65
00JGC00
WJ Factory Components Average Life Expectancy
I thought it would be useful to try and see what the average life expectancy is for various factory components on the WJ.
Here are some threads to vote in (if you've replaced the factory part) and to review:
Alternator:
http://www.jeepforum.com/forum/f310/...tancy-1345240/
Starter:
http://www.jeepforum.com/forum/f310/...tancy-1345247/
Fuel Pump:
http://www.jeepforum.com/forum/f310/...tancy-1345595/
Driver-Side Exhaust Manifold Bolts:
http://www.jeepforum.com/forum/f310/...n-yet-1345730/
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline   Reply With Quote
Unread 05-17-2012, 11:11 AM   #66
narnwv
narnwv's Avatar
now that I have the power to work on the FAQ thread, I'm going to start dumping more posts in here to add to the finalized FAQ thread.
http://www.jeepforum.com/forum/f310/...ite-up-733669/
http://www.jeepforum.com/forum/f310/...ation-1369979/
~Aaron
narnwv is offline   Reply With Quote
Unread 06-25-2012, 01:53 PM   #67
narnwv
narnwv's Avatar
wj fan relay test
http://troubleshootmyvehicle.com/jee...lay_test_1.php
~Aaron
Unread 06-25-2012, 03:09 PM   #68
ChrisHager
ChrisHager's Avatar
Originally Posted by narnwv View Post
I'm too lazy to find it, but it would be nice to have a link to AP's build thread where he does the 5 speed swap. I've seen a few questions on it recently, and one does pop up every now and then.
http://www.jeepforum.com/forum/f197/...ml#post9165304
Hers: 2000 TJ
WJ Torque Specs
Unread 07-01-2012, 12:17 AM   #69
j4bs4209333
Save $$ on parts at Advance Auto huge discounts
If you have an Advance Auto Parts near you here's how to save $$. You shop online, add your items to your cart and make sure you select pickup in store at the location you want to pick them up at. Once you're done shopping, before you pay, go to www.retailmenot.com and get the coupon code that gives the best discount for the dollar amount you spend. You can enter the coupon code before checking out to make sure it works. Once you have the best code for the $$ amount then you pay online, print out the receipt and go pick it up at the store you selected. The website says ready in one hour, but I've gone there many times 5 minutes after paying and they are fine with it. You can pay with a credit card or paypal. A lot of new parts end being cheaper than junkyard parts because of the coupon codes. The coupons are not valid for oil and most other fluids, otherwise they work on mostly everything else. If you're smart, or cheap like I am, you have to figure out if it's better to do 2 separate orders. Example...you need 2 parts @ $100 each, they have a coupon for $50 off a $150 purchase, but you're better off buying the items in 2 separate transactions because you get $35 off an $85 purchase so you end up with $70 off instead of $50. Since I'm super cheap I use them all the time for parts and I know the codes to use for the best discounts. Below is a list of the best ones to use. Do not use the % off codes unless you're buying one high priced item over $250. Spend a minute to look for better codes, the % off codes don't save you that much.
Code Description
RAF7JA1102 $35 Off Orders of $85 or More (the biggest discount)
BIG30 $30 Off Orders of $75 or More
RETMENOT123 $10 off $30--$20 off $50--$30 off $100
BIG15X $15 Off Orders of $40 or More
If you are spending $150 or more and it's on a single item use this one
VISA $50 off $150
If you buy one single item over $250 this one gets the best discount
P20 20% off entire order
j4bs4209333 is offline   Reply With Quote
Unread 07-06-2012, 01:07 AM   #70
kody22
Code Description
VISA $50 off $150
That's good to know
kody22 is offline   Reply With Quote
Unread 07-20-2012, 10:26 AM   #71
jeepittydodah
I just completed this Axle seal leak job, in my driveway. Darn sway bar bolts are difficult to wrench back in all the way, I may have to hit them with air. My big learning tip is to be careful when reinstalling the axle. One side of the square flange has a little indent on it which matches up to a protruding brake part. First timers make sure you match that indent up correctly or 1 of your 4 bolts will not line up with its hole in hub assembly and you will not be able to put the axle in the shaft all the way, much less bolt up the 4 bolts. And access to the top bolts on the Diff pan is a little easier if you lower the axle just low enough below the gas tank hinderance to reach them. This was not that difficult a job, even in the driveway, thanks to the excellent pictures provided. But access to a lift would have made it fairly painless. thanks for the instructions, saved me a bunch of money over dealer estimate ($400 at least).
jeepittydodah is offline   Reply With Quote
Unread 07-26-2012, 08:21 AM   #72
ChrisHager
ChrisHager's Avatar
WJ Torque Specs - Complete List
Hers: 2000 TJ
WJ Torque Specs
Unread 07-26-2012, 08:27 AM   #73
narnwv
narnwv's Avatar
Originally Posted by ChrisHager View Post
Thanks! I'm going to be working on the FAQ next week when I'm lounging on the beach.
~Aaron
Unread 08-21-2012, 07:22 PM   #74
kristi5683
kristi5683's Avatar
Axle Shaft lengths for Varilock and Non-Varilock systems:
Non-Varilock:
long side- 35 1/8"
short side-19 3/8"
Varilock:
long side- 36 3/8"
short side-18 3/8"
Also a nice little tip for axle shaft seal replacements:
A CV joint Cage fits nicely around the shaft seals without crushing the rubber. If you ever replace your CV joints or have one go bad, keep the cage. I couldnt find my seal installer tool anywhere and ruined 2 seals trying to get it in until I decided to improvise. It works nicely since the cage also allows you to hold it in position better than a lot of tools.It's important to remember if you do use it for this, don't plan on ever putting it back in a CV joint.
kristi5683 is offline   Reply With Quote
Unread 08-27-2012, 07:26 AM   #75
ChrisHager
ChrisHager's Avatar
Hmmm... I thought this was in here already but I don't see it.
2004 4.0 I6 Jeep Grand Cherokee Camshaft, Timing Set, and Lifter Replacement
Includes removal/installation of fascia, radiator, head, camshaft/lifters, timing set, proper timing of the CPS, etc.
Hers: 2000 TJ
WJ Torque Specs
