WJ electical issues - JeepForum.com
post #1 of 19 Old 09-29-2013, 06:22 PM Thread Starter
newt86
WJ electical issues
my 99 WJ has had electrical problems since I have it. The gauges don't work and the heat/ac doesn't work. I fixed 3 wires that were broken in the drivers door and now it starts but quits after 2 seconds. Anyone help with this?
newt86 is offline
post #2 of 19 Old 09-29-2013, 06:58 PM
narnwv
narnwv's Avatar
exactly 2 seconds? Then the SKIM module is unplugged/shorted. I bet you have a Key symbol on the dash with a line through it.
~Aaron
narnwv is offline
post #3 of 19 Old 09-29-2013, 07:24 PM Thread Starter
newt86
the key symbol is there. Where is the SKIM module located?
newt86 is offline
post #4 of 19 Old 09-29-2013, 07:29 PM
narnwv
narnwv's Avatar
literally around the ignition switch.
http://www.wjjeeps.com/modules.htm
~Aaron
narnwv is offline
post #5 of 19 Old 09-29-2013, 08:06 PM Thread Starter
newt86
thanks. I will check it out tomorrow. any thoughts on the heat/ac?
newt86 is offline
post #6 of 19 Old 10-01-2013, 07:27 AM
narnwv
narnwv's Avatar
Elaborate on "doesn't work"
Typing on phones sucks.
~Aaron
narnwv is offline
post #7 of 19 Old 10-01-2013, 08:11 PM Thread Starter
newt86
no fan, heat comes out at your feet. all this stuff happened all at once. could it be a bcm problem?
newt86 is offline
post #8 of 19 Old 10-01-2013, 11:52 PM
rep-tile
Cash 4 Clunkers Survivor
rep-tile's Avatar
It could be a grounding issue. The AC and SKIM module share the same ground point, so does the instrument cluster.
rep-tile is offline
post #9 of 19 Old 10-02-2013, 07:22 PM Thread Starter
newt86
rep-tile, is that ground the one behind the radio? I just got a wiring diagram from a friend at a dealer. A little overwhelming...
newt86 is offline
post #10 of 19 Old 10-02-2013, 11:35 PM
rep-tile
rep-tile's Avatar
Go figure. I do know they've changed the location of the ground over the years, recent WJs have it near the airbag module underneath the center floor console (passenger compartment), older ones may have it behind the light switch.
Regardless of the year, the primary ground location is between the negative of the battery and the frame, all ground points (except for the engine grounds) depend on it. Inspect your grounds very carefully, they might look fine in appearance, but you could find corrossion or rust once you take them apart. Inspect the positive battery cable as well. The OEM battery cables are junk to start with, so it is very common to find corrosion there.
rep-tile is offline
post #11 of 19 Old 10-11-2013, 05:59 PM Thread Starter
newt86
borrowed a scan tool. says not communicating with drivers door, serial link malfunction, and EMS status malfunction. I understand the door issue, the other 2 I have no idea about. could it be the door module has gone bad or a bcm problem?
newt86 is offline
post #12 of 19 Old 10-11-2013, 07:12 PM
trojanbrutha
Wj Hi guys
I'm a noob around here, but I have a similar problem with the temp controls that occurred after I replaced the factory HU. The ground was attached to the back of the stereo that I removed, along with a connector that appears to have two wires.
trojanbrutha is offline
post #13 of 19 Old 11-11-2013, 08:40 PM Thread Starter
newt86
Replaced PCM. Gauges work, doors work, fan works, overhead works. But, still no heat.
newt86 is offline
post #14 of 19 Old 11-11-2013, 08:53 PM
fletchFL
You mentioned before that heat would find its way out of the floor vents when the fan was not working? Is your fan now working, but you have no heat coming from any vents? Heard any strange clicking noises inside the dash?
04 WJ Laredo SelecTrac - Stock in every way that counts.
fletchFL is offline
post #15 of 19 Old 11-15-2013, 12:25 PM Thread Starter
newt86
The fan is working. There are noises coming from under the dash and there is no heat. The AC needs recharged, could this be the problem?
newt86 is offline
