Wj dies when ideling in trafic - Page 2 - JeepForum.com
post #16 of 24 Old 07-16-2013, 09:55 AM
JimmydaGreek
2015 JK Wrangler
Anyone have any part numbers please for the 4.7L non HO?
2015 JK Unlimited Rubicon Loaded and Modded
JimmydaGreek is offline
post #17 of 24 Old 07-16-2013, 05:32 PM
zephyr80
Which part numbers are you looking for?
Sent from your back seat!!!
zephyr80 is offline
post #18 of 24 Old 07-17-2013, 11:00 AM
JimmydaGreek
2015 JK Wrangler
Crankcase position sensor and Camshaft position sensor please if you have them. Thanks...
post #19 of 24 Old 07-17-2013, 11:20 AM
99WJnDa702
Look on Rock Auto's website. You can narrow the parts you need by filling out your year, make, model info.
99WJnDa702 is offline
post #20 of 24 Old 07-17-2013, 12:51 PM
JimmydaGreek
2015 JK Wrangler
Actually did that and the Camshaft Position Sensor is the one I find with correct name. Nothing with "Crankcase" and "Position" in one part, I see "Crankshaft" Position Sensor, "Crank" Sensor but don't know if these are the same? A google search only finds Crankshaft not Crankcase so I assume they're the same.
post #21 of 24 Old 07-17-2013, 01:09 PM
zephyr80
Crankshaft is the one you want
zephyr80 is offline
post #22 of 24 Old 07-17-2013, 01:14 PM
JimmydaGreek
2015 JK Wrangler
Thanks, I read it's behind the starter so I have some work to do; doesn't look too difficult. Thanks again...
post #23 of 24 Old 07-17-2013, 06:58 PM
zephyr80
I just replaced mine, it would have been much easier if the engine wasnt so hot
zephyr80 is offline
post #24 of 24 Old 07-18-2013, 09:55 AM
JimmydaGreek
2015 JK Wrangler
LOL...mine has been sitting cold for a couple months, suspension is apart and I just start it every other day to keep the engine lubed. Installing adj front and rear CA's upper and lower, bushings, balljoints and a CB. The fun never stops!
