Wj dies when ideling in trafic - JeepForum.com
post #1 of 24 Old 12-23-2012, 08:57 AM Thread Starter
norwaywj
2006 XK Commander
I just got a new problem. Two times today I was in heavy traffic and when the traffic stopped completely and the wj was ideling it stoped. After putting it in park I turned it off and on and the problem was gone. It also happend one more time when ideling. I scanned it with an ultra gauge, but did not get any fault codes. It does not happen all the time. Its very windy today and about -3 C så the cold should not be a problem
norwaywj is offline
post #2 of 24 Old 12-23-2012, 11:36 AM
lesterabjr
Crankcase position sensor & or camshaft position sensor. Both are a pain to replace but fairly cheap. Should cure your woes
lesterabjr is offline
post #3 of 24 Old 12-23-2012, 11:38 AM
lesterabjr
Crankcase position sensor &/or camshaft position sensor. Both are a pain to change but fairly cheap. I would go ahead & swap both. Should cure your woes before it gets worse, & it WILL get worse
post #4 of 24 Old 12-23-2012, 12:15 PM Thread Starter
norwaywj
2006 XK Commander
Is it hard to locate them or is it labour intensive to do the job ?
When it gets worse, will it also die when driving ?
norwaywj is offline
post #5 of 24 Old 12-23-2012, 12:21 PM
USFORCES
Use OEM aftermarket don't last worth a crap...
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #6 of 24 Old 12-23-2012, 12:23 PM
lesterabjr
Not hard to locate just a pain to get at, & yes it WILl start to die while driving. I fixed my 4.7 for about $55 plus about 2 hours of knuckle busting.
post #7 of 24 Old 12-23-2012, 12:24 PM
Mp5ben
2005 WK
Try cleaning your throttle body and IAC before you start throwing money around. My WJ had this problem and in about 10 minutes my WJ was idling perfectly again. Very simple job
Mp5ben is offline
post #8 of 24 Old 12-23-2012, 12:35 PM Thread Starter
norwaywj
2006 XK Commander
Thanks, What is the IAC ?
Not liking the idea of the engine dieing at high speeds.
norwaywj is offline
post #9 of 24 Old 12-23-2012, 12:45 PM
Thomahawk
2006 XK Commander
Idle air Control, its in your tb Throttle body,
Check out wjjeeps.com
All the info you need on sensors and everything.
http://www.wjjeeps.com/service/tbody.htm
Lykke til Mr, og god jul!
Buildthread
Thomahawk is offline
post #10 of 24 Old 12-23-2012, 01:05 PM Thread Starter
norwaywj
2006 XK Commander
Thanks, god jul !
norwaywj is offline
post #11 of 24 Old 12-23-2012, 10:01 PM
ZB_WJ
Also, please post your year and engine size. Some may not be able to see it on mobile.
Read the TSB on heat soak as well (if it's a 4.0)
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #12 of 24 Old 12-24-2012, 12:56 AM Thread Starter
norwaywj
2006 XK Commander
Its an 2004 4.7 HO
norwaywj is offline
post #13 of 24 Old 12-25-2012, 12:37 PM Thread Starter
norwaywj
2006 XK Commander
Anybody knows what happens when it dies at highway speeds ? Does the power steering still works ? Does the brakes work like normal ?
norwaywj is offline
post #14 of 24 Old 02-09-2013, 02:23 PM Thread Starter
norwaywj
2006 XK Commander
Update. The TPS and IAC arrived first. Changed them, but the problem was still there. Have now changed the crank and camshaft position sensors and the problems seems to have gone away
norwaywj is offline
post #15 of 24 Old 07-15-2013, 11:22 PM
zephyr80
Yes, no, no. It will be easy to steer due to the wheels are spinning, but braking will be difficult.
Sent from your back seat!!!
zephyr80 is offline
