WJ Codes - P0138, P0700, P1494 - JeepForum.com
post #1 of 14 Old 04-25-2010, 04:48 PM Thread Starter
jeeplover93
Yesterday I pulled some codes on my Jeep (1999 Grand Cherokee 4.7L) using the key in the ignition method.
Current problems that I notice on my Jeep:
  • Check engine light on
  • Exhast sort of white with a strange scent
  • Transmission shifts hard
Codes I got:
  • P0138: O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
  • P0700: Check Transmission DTC's (This code indicates that the EATX (Transmission controller) has an active fault and has illuminated the MIL via a BUS message. The specific fault must be acquired from the EATX via a DRBIII tool. (Input or Output Speed Sensor failures often cause this code and are a common failure part on WJ Grand Cherokees).)
  • P1494: Leak Detection Pump Sw or Mechanical Fault (Incorrect input state detected for the Leak Detection Pump (LDP) pressure switch.)
Can someone please help me better explain what these are? If they need to be fixed or if the car is safe to drive? Could any of these cause the unusual exhaust?
Thanks in advance!
jeeplover93 is offline
post #2 of 14 Old 04-25-2010, 07:58 PM
wonderbrd937
p0138- clean your 02 sensor and maybe you will have to replace it. dont take my word on this but im pretty sure its the last one by the cat
good luck
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
wonderbrd937 is offline
post #3 of 14 Old 09-14-2010, 06:46 AM
SplitNail
What do you do about P1494? My jeep just had this come up...
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #4 of 14 Old 09-14-2010, 07:38 AM
99JGCWJ
The P1494 may not be the pump itself. When I got that code it turned out to be just an old hose that needed to be replaced. It won't harm your engine at all but you won't pass emissions either.
SIX IN A ROW MAKES IT GO!!!
99JGCWJ is offline
post #5 of 14 Old 09-14-2010, 07:42 AM
SplitNail
I can actually hear the leak. I'll have to take off the bumper and look.
post #6 of 14 Old 09-14-2010, 11:24 AM
SplitNail
Okay so I didnt find anything..... I cleared the code and its staying off.. I wounder what will happen!
post #7 of 14 Old 09-15-2010, 07:35 AM
SplitNail
So to no surprise t CEL ame back on this morning, what should I start checking? The code is p1494
post #8 of 14 Old 09-15-2010, 11:02 AM
99JGCWJ
All your hoses from the pump are good? Maybe it's the pump itself?
99JGCWJ is offline
post #9 of 14 Old 09-15-2010, 12:57 PM
SplitNail
I'll check the hoses more today, maybe the gas cap? I had a friend say it could be a vaccum leak. Anyone have anymore ideas? Could it be the sensor itself? And where is it?
post #10 of 14 Old 09-15-2010, 06:19 PM
SplitNail
Bump?
10char
post #11 of 14 Old 02-15-2011, 07:33 AM
yrkoverland
What did you ever find out on this?
Mine has the same code. I need to check hoses yet but thought i'd be armed with as much info as I can
2000 WJ- 4.7L HO swap, 247, 4" tera-flex lift, 32's, KOR Rock Rails, IRO Skid, etc...
2007 VW Touareg V10 TDI gobs of torque!
2004 Audi A8L Luxobarge
2008 Z06 cammed and slammed
yrkoverland is offline
post #12 of 14 Old 02-15-2011, 08:01 AM
SplitNail
Mine shorted out and I had to replace it. I have seen cracked hoses cause that. Also.. There is a filter in there you can get from the dealer for $10. I have seen that too.
post #13 of 14 Old 02-15-2011, 10:28 AM
yrkoverland
Thank you sir
post #14 of 14 Old 02-15-2011, 10:31 AM
SplitNail
Thank you sir
You are welcome!
exhaust , p0138 , p0700 , p1494 , transmission
Code P1494 PAPA1 ZJ Grand Cherokee Forum 8 05-30-2012 01:47 PM
4.7 with a P1494 code marciad32 ZJ Grand Cherokee Forum 0 02-11-2009 06:54 AM
Got a CEL today -- P1494 P NUT ZJ Grand Cherokee Forum 8 04-26-2008 03:21 AM
how to fix eng. code p1494 rodster ZJ Grand Cherokee Forum 0 07-11-2006 08:31 AM
Error codes P0325 and P0700 Jenseno9 ZJ Grand Cherokee Forum 4 05-07-2005 09:23 AM
