WJ Clock Spring Replacement - JeepForum.com
post #1 of 53 Old 10-23-2008, 09:51 AM Thread Starter
thisguyhasadd2
I used search and couldnt find a good thread for DIY clockspring replacement.
Anyone got one?
thisguyhasadd2 is offline
post #2 of 53 Old 11-01-2008, 11:09 PM
Cebby
Disconnect the negative battery terminal.
Remove the airbag.
Remove the steering wheel.
Replace the clockspring.
Reverse order for reassembly.
I did this a while ago, but didn't get my writeup done yet. I'll try to find my pics.
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
post #3 of 53 Old 11-01-2008, 11:12 PM
Cebby
Post deleted.
WTF's up with the forum? White screen after posting? Sumthin's fubared.
Cebby is offline
post #4 of 53 Old 11-14-2008, 09:51 PM Thread Starter
thisguyhasadd2
any special tools required? is it fairly easy?
post #5 of 53 Old 11-15-2008, 01:24 PM
Cebby
Easy once the steering wheel is off. You need a couple of different jaw type gear pullers to get the wheel off. I used the arms off a small 6" gear puller and the center section of an 8" gear puller. This combo got the wheel off without too much drama.
Cebby is offline
post #6 of 53 Old 11-16-2008, 02:59 PM
rarmstrong0125
1994 XJ Cherokee
I trying to change the clock spring and am stuck at removing the wheel. I tried a wheel puller that the lend out at auto parts store and I can't get it to budge. I'm wondering if I'm missing something here. I took these steps:
- disconnect battery (and wait)
- remove airbag
- remove trim behind wheel
- loosen the nut in the center of the wheel, backed out but did not fully remove
- used wheel puller with arms that have cleats and slip under the 9 and 3 o'clock positions of the wheel.
- tighten, tighten, --- slips OFF!
Can anyone help?!?
thanks,
Richard
rarmstrong0125 is offline
post #7 of 53 Old 11-16-2008, 03:55 PM
rarmstrong0125
1994 XJ Cherokee
thanks for the advice. Is there a particular one that you know works? I just tried a gear-puller (2 jawed) and did not have a lot of luck with that one either.
post #8 of 53 Old 11-19-2008, 12:48 PM Thread Starter
thisguyhasadd2
rarmstrong would you mind taking some pictures and such as your doing this.... it would be most appreciated. Also why are you replacing your clock spring what symptoms does your wj have?
post #9 of 53 Old 11-19-2008, 01:02 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Yes I went back and forth to auto zone several times till I found the right one. When used as a 2 jaw puller, place the jaws in the notches (see the crappy black circles in pic below)
http://www.autozone.com/selectedZip,.../selectZip.htm
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #10 of 53 Old 11-19-2008, 01:39 PM
Vanquish
Originally Posted by QuadraTokn View Post
The only puller that works to get the steering wheel of is a 3 jaw puller. trust me.
The OEM steering wheel was designed to be pulled with a 2-jaw puller. There are recesses in the wheel for a two jaw puller to catch and pop the wheel off. Check your FSM if you have one!
The puller needs to have the right reach and puller jaws, maybe thats where some of you are running into problems. I used a Sears Craftsman two jaw puller and it worked fine. Make sure where you pull the wheel the jaws are seated properly and don't let the puller twist as you tighten it down to pop the wheel.
Vanquish is offline
post #11 of 53 Old 11-19-2008, 01:46 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Whoops!! You're right, i remembered wrong, I edited my posts...
post #12 of 53 Old 11-19-2008, 07:34 PM Thread Starter
thisguyhasadd2
thanks for that picture is there anyone with one of the actual clock spring and any specifications for installing it? also is it just wear and tear that it fails?
post #13 of 53 Old 11-19-2008, 07:39 PM Thread Starter
thisguyhasadd2
so that is not the right jaw puller?
post #14 of 53 Old 11-22-2008, 10:09 PM Thread Starter
thisguyhasadd2
aynoneeeeeeeeeeeeeee?
post #15 of 53 Old 11-23-2008, 02:45 AM
Cebby
See post #2.
Here are pics: http://rigs.corequipment.com/Cebby/0...e/clockspring/
I used the arms from a 6" 3-arm puller on an 8" 2-arm puller rig. That was the only combo I could find that would work to remove the wheel.
Cebby is offline
Clock Spring Pitch Black ZJ Grand Cherokee Forum 7 02-22-2012 02:20 PM
Clock spring rkoz1 WK Grand Cherokee & XK Commander Forum 4 05-23-2008 04:47 AM
bad clock spring z rated ZJ Grand Cherokee Forum 2 12-27-2007 08:22 PM
WJ Air bag clock spring WHERE TO BUY ntaousakis ZJ Grand Cherokee Forum 4 12-25-2007 11:43 AM
Replacing the clock spring hunchback ZJ Grand Cherokee Forum 0 03-16-2007 03:43 PM
