wj bump steer - JeepForum.com
post #1 of 5 Old 05-28-2011, 05:40 PM Thread Starter
tidalbreak
wj bump steer
Hello all I have a 2000 4.7 with ome hd's up front with a BB and ome med's on in rear with addco and Bilstien's. JkS trac all from Kolak. When I put th BB on in front to level it out i got bump steer only once in awhile but violently. looks like I need a drop pitman arm to correct the proper angles. I don't have sway bar extesions wouls the help. its my wifes ddand I want it to be safe for her. P.S she has already flipped our xj so I want to keep her out of the ditch. ha ha.
tidalbreak is offline
post #2 of 5 Old 05-29-2011, 01:51 PM
skain8
skain8's Avatar
Bumpsteer really isn't "violent". And bumpsteer would be over any bump. Maybe you experienced death wobble.
Either way, you don't need or want a drop pitman arm. How's your toe? Is your trackbar uber tight?
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #3 of 5 Old 05-30-2011, 07:57 PM
mscottnelson
Wj
I also had pretty bad bump steer or maybe it was the infamous "death wobble", but when I replaced the inner tie-rod ends (aka drag link ends) it all but went away. I still have a very slight vibration when I hit a pretty hard bump at about 40-45, but I am hoping that it will go away after I replace the actual TRE's here in a couple weeks. You don't have to have an alignment after the drag link ends, but when you do the TRE's you need to. This might not be what your problem is, but it might be something to check out.
. _____ 0 __ 0
/___l_l_,\____\,_____
l__--l_l__l---- ( )JEEP( )
{_(o)_} {_(o)_}-o-)_}
Colorado Jeepin
mscottnelson is offline
post #4 of 5 Old 05-31-2011, 02:34 PM Thread Starter
tidalbreak
My track bar is tight and I am going to get a fresh alignment with replacing all tre's. I know what dw is and I don't have that at any speed, but I first hand experienced it the other day when I hit a rut or pot hole and the bump steer went into serious dw. I had to completely stop the jeep and restart. Keep in mind this is my wifes DD and I may drive it maybe twice a week. I have searched and searched and know about no drop pitman arms, track bar drop brakets etc.... but sometimes you have to ask with all jeeps being diff beasts.
post #5 of 5 Old 05-31-2011, 04:05 PM
WiCkeDuDe
WiCkeDuDe's Avatar
You dont want to run the drop pitman arm with an adjustable trackbar if thats what you are running.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
DIY Bump Stops fizzer WJ Grand Cherokee Forum 24 11-15-2011 11:33 AM
Bump Steer Issues (NOT DEATHWOBBE) w0mps WJ Grand Cherokee Forum 11 04-28-2011 06:11 AM
99 WJ bump steer ledfoot02 WJ Grand Cherokee Forum 1 01-26-2011 10:16 PM
bump stops gc3381 WJ Grand Cherokee Forum 4 12-20-2010 12:05 PM
still have a little bump steer travisbanshee67 WJ Grand Cherokee Forum 5 12-17-2010 07:19 AM
