WJ Axle Swap - JeepForum.com
post #1 of 22 Old 07-22-2014, 01:44 PM Thread Starter
Crankcase
Wj WJ Axle Swap
Just bought front and rear vari-lok axles D30/D44a 3.73 to replace my D30/D35 3.55 axles for my 242 4.0.
I know a thing or two on the drive train design on the WJ, but is there anything I should be weary of? And/or gain access to vital online resources.
Crankcase is offline
post #2 of 22 Old 07-22-2014, 01:57 PM
99WJ539918
If you have the complete able assemblies then no, you'll be fine. They're a direct swap. Make sure you have the property fluid.
Build Thread
99WJ539918 is offline
post #3 of 22 Old 07-23-2014, 12:02 AM
2ndhandWJman
I did the same swap last year on my '03 Laredo. The axles bolts in 100%, no fuss. I had to have my rear driveshaft shortened about 1.5", and when I swapped to the ' u-joint on both ends ' of a front drive shaft, I was at about 1.5" too short. I provided the shop a drive shaft that was the correct diameter, just way too long. They used it as raw material and made a front shaft that fit nicely.
2ndhandWJman is offline
post #4 of 22 Old 07-23-2014, 01:17 AM
evilcairn
Pew , swap 100% . Need a 44a without lsd :'(
WJ 2001 V8 , 6.5" lift IRO , 35" BF , Front DS TomWoods mutilCV, Fender Iceland, TrueTrac Eaton Front, Gears 4:56 , Custom Front bumper, custom rock slidder ....
evilcairn is offline
post #5 of 22 Old 07-23-2014, 11:26 AM Thread Starter
Crankcase
I am going to be given the rear DS with the rear axle. Currently I have a single u-joint on each end of the rear. Not sure what the new setup will be.
As for the front, the new axle will have a u-joint yoke, which is the same as my current setup; U-joint yoke and rezeppa TC connection.
It should be a plug and play driveshaft wise? The D30 will be identical, and the rear I will be provided with the new DS. Will the splines match up on the rear DS transfercase side?
post #6 of 22 Old 07-26-2014, 09:49 AM
99WJ539918
If you're getting the Dana 44A then, unless it was swapped prior, it came out of a 4.7L and I think the 4.7L rear driveshaft is shorter than your 4.0L.
Build Thread
post #7 of 22 Old 07-26-2014, 03:38 PM
2ndhandWJman
I know that when I was gathering the pieces for my conversion, the "donor" rear DS came from the V8 Jerp that the axles came from. The splined output shaft at the T-case ( the stock 242 that was in my WJ) mated fine with the donor DS yoke, the tubing was just too short.
post #8 of 22 Old 07-27-2014, 08:38 PM Thread Starter
Crankcase
So you're saying, since I have the rear DS that came from the V8/D44a Jeep, that I will be fine? I only ask because I am changing out the u-joints on the DS and I need to know which ones to install them onto.
post #9 of 22 Old 07-27-2014, 08:43 PM
2ndhandWJman
You should be OK as far as the splines are concerned, but my overall DS was too short to work. I had to get it re-tubed to a longer length for it to work.
post #10 of 22 Old 07-27-2014, 09:09 PM Thread Starter
Crankcase
But I have both:
4.0 242 D35 rear DS
4.7 247 D44a rear DS
I'm under the impression that the latter option shaft would be the correct length for the axle swap
post #11 of 22 Old 07-28-2014, 02:05 PM
2ndhandWJman
I never tried the stock Dana 30 rear drive shaft, it got scrapped with the old axle so I can't tell you for certain if it will bolt up or not. Once you get the rear axle swapped, a tape measure will give you the answers that you need.
post #12 of 22 Old 07-28-2014, 08:51 PM Thread Starter
Crankcase
Drive shaft measurement is quite new to me.. Where on the slip yoke (transfer case) and where on the diff yoke do I measure exactly?
post #13 of 22 Old 07-29-2014, 05:32 AM
wvracer821
wvracer821's Avatar
When I swapped in my D44a I used my factory rear shaft (4.0L 242 D35) it is about an inch and some change longer than the D44A but at 3 inches of lift it was just fine. The D44a pinion is a little longer that the D35, that is the reason for the difference in shaft length. Front shaft is the same length across the board as far as I know. I Did swap in a front shaft from a ZJ becasue it had a double cardan joint and it is a hair longer. I'm at 6.5 inches of lift not with no negative vibes
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #14 of 22 Old 07-30-2014, 09:31 AM Thread Starter
Crankcase
I'm at 2" of lift, coils with new isolators all round. Little less lift than you, I'll use both shafts and see which one is a better fit.
Thanks for the input wvracer.
post #15 of 22 Old 07-30-2014, 08:24 PM
dlundblad
2003 WJ
How hard was it to reconnect the parking brake cables?
This is good to know. I too am at 2 inches of lift. Be sure to post whether or not the 4.0/ D35 drive shaft works.
03 WJ Laredo 4.Sl0w
16" JK alloy take-offs
2" BB, Goodyear AT's
dlundblad is offline
