WJ auto transmission starting in 2nd gear - JeepForum.com
post #1 of 8 Old 06-21-2012, 04:43 PM Thread Starter
BeepBeepJeep777
I thought my transmission was slipping but then I realized that its starting in 2nd gear unless I put the shifter down to 1st to start out. What gives?
I know I need a transmission fluid change. Will this help the problem or maybe a bad sensor?
Help please.
Thanks!
BeepBeepJeep777 is offline
post #2 of 8 Old 06-21-2012, 05:41 PM
SoBStevens
1995 XJ Cherokee
Change the fluid and the filters if its needed to be done start there
0811
1995 XJ- Automatic- 220k
2002 WJ- Gone but not forgotten.
SoBStevens is offline
post #3 of 8 Old 06-21-2012, 07:12 PM
dtrkyman
2013 WK
be careful with fluid change, if it has not been done regularly it may be the demise of your trans.
dtrkyman is online now
post #4 of 8 Old 06-21-2012, 11:59 PM
kfxnando
on my 4.7 V8,was having issues also, went into limp mode, P0700, bad changes from second to third
changed fluid and both filters
and since then, no more limp mode, no more codes, second to third issue much better, believe my box might of had the wrong fluid in when I bought it, so need to do another just fluid change to dilute what was in there
so yes go ahead and start with a fluid and filter change, nothing to loose
good luck
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #5 of 8 Old 06-22-2012, 07:20 AM
ibreb3
Any check engine light? Mine did that once and threw a p1752 code (I think that was the code) I cleared it and it hasn't done it since but I'm going to change the governor pressure sensor and solenoid when I do my filter and fluid cause with research I found these are the most common culprits of this scenario. But I would check any codes first before you just throw money at it.
ibreb3 is offline
post #6 of 8 Old 06-22-2012, 12:42 PM
RyanSBenson
X2 on what ibreb3 said. I had a similar issue. Cant remember if it was the sensor or the solenoid because I ended up having the dealer do that change for me. Fixed it right up though.
01' WJ Laredo Stock
96' XJ Sold
RyanSBenson is offline
post #7 of 8 Old 06-22-2012, 02:15 PM
jtmizzell
same problem. i have no check engine light on. what do i need to do to fix this?? already changed filter and fluid. someone help !!
jtmizzell is offline
post #8 of 8 Old 06-22-2012, 04:36 PM
SoBStevens
1995 XJ Cherokee
Change the solenoid then mang
0811
03 Grand Cherokee 4.7L auto Starting problems Meola WJ Grand Cherokee Forum 4 05-28-2012 09:46 PM
No 4th Gear on Auto bobknott WJ Grand Cherokee Forum 12 11-08-2011 02:31 PM
diagnosing Auto transmission. tassie-cherokee WJ Grand Cherokee Forum 5 07-08-2011 02:16 AM
starting, engine warning light and auto probs pistolpete1978 WJ Grand Cherokee Forum 1 10-09-2010 07:08 AM
code 0700, starting out in 2nd gear Howiedooit WJ Grand Cherokee Forum 2 09-08-2010 09:04 PM
