wj aluminum rad - JeepForum.com
post #1 of 10 Old 10-15-2013, 11:26 PM Thread Starter
xrattler
Wj wj aluminum rad
Ok here goes. Overheating wj 2000 287 cu.in. v-8. Tis ok on the freeway
but low speeds or 4wd it really starts to cook and around town and
small 1/4 mile (hills). Has anyone know or have experience in this field
with all aluminum radiators. I've found that some are wider than others,
so the real question here is about the condenser. Will these aluminum
rads. fit without to much shoehorning?
xrattler is offline
post #2 of 10 Old 10-16-2013, 12:29 AM
Fellows45
I wouldnt be looking at the radiator man. if its working on the freeway then that means your rad is working. I would look at the fan relays or the fan motor itself and make sure its kicking on.
2002 Jeep WJ, 4.7, EBC Stage 4 brakes, Bilstein shocks (Still In progress)
1989 Wrangler YJ 2.5, 2 inch body lift, 33 inch tires
Fellows45 is offline
post #3 of 10 Old 10-16-2013, 04:26 AM
86cj74.2L
86cj74.2L's Avatar
Doesn't he also have a viscous fan too? That could be bad also. And one that should be working all the time.
But yes electric fan if installed should kick on and cool down.
86cj74.2L is online now
post #4 of 10 Old 10-16-2013, 05:01 AM
99WJ539918
Even if the viscous fan didn't work he still shouldn't overheat. The early 4.7L's don't use the power steering for the fan, so I agree with above. Check your electric fan and relay.
Build Thread
99WJ539918 is offline
post #5 of 10 Old 10-16-2013, 09:59 AM
86cj74.2L
86cj74.2L's Avatar
And viscious fan.
I thought they only came with the electric fan if it had the tow package. He may not even have one.
post #6 of 10 Old 10-16-2013, 11:18 AM
99WJ539918
All come with the electric fans. The tow package would've included the clutch fan in a WJ like mine.
Build Thread
post #7 of 10 Old 10-16-2013, 02:10 PM
86cj74.2L
86cj74.2L's Avatar
Ok I thought it was the other way around.
post #8 of 10 Old 10-16-2013, 06:14 PM
Double E
Double E's Avatar
Do this...when it starts to over heat on the highway, run the heat full blast. windows down so you don't fry. If it keeps the temp low, it is a radiator issue. If not, it's a water pump issue. Or it could be failing to hold pressure and the cap is leaking...
My bet is running the heat will solve it and you need a radiator. Aluminum ones are rare like frog hair. An OEM spec will do the trick for another 4 years.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #9 of 10 Old 10-16-2013, 09:59 PM
Cebby
Griffin Rad FTW
2000 WJ Laredo 4.0 4x4 Taupe Frost - Clayton LA Front/Rear | IRO 3" Springs + 3/4" KOR | Bilstein Shocks | JKS Discos/Trackbar/Draglink & Tierod | Dual KOR Stabs | Spidertrax Spacers | 265/70R17 Duratrac's on JK 17's | Black Magic Brakes w/Centric Rotors | Akebono Calipers | Griffin Rad | K&N Drop in | Magnaflow Cat & Muffler shorty setup | Diehard Platinum (Odyssey) | RB1-NAV-Sirius-Chg-iPod | OEM Tow Hooks F/R
Cebby is offline
post #10 of 10 Old 10-16-2013, 11:09 PM Thread Starter
xrattler
my own reply
My V-8 does not get hot on the freeway.
It gets cooking at very low speeds,city driving, and going up small
inclines or hills.It does have the factory tow package, if you want
to call it that.I just installed a Hayden clutch fan last month. The electric
fan does come on, but I do not know how to tell if it is running on low
speed or high speed, but my way of thinking is that these vehicles
should not need secondary fans.That just tells me that they are way
under cooled. These vehicles need a lot more cooling, like another
gallon or more. I know these are stuffed under the hood, but the engineers
should know better than that. I would get into the wife's '07 and the way
they cobbled it up, but I would have to write a short novel on it.
This is about aluminum rads. remind you.
Thank you all, more input please.
xrattler is offline
