wj all over the road. help now - Page 2 - JeepForum.com
post #16 of 20 Old 12-20-2011, 03:45 PM
WJChris
WJChris's Avatar
THIS:
Originally Posted by Terminator2 View Post
Turn wheel and wheel stays turned you need to have the toe, and caster checked. Caster needs to be around 4.5-5.5* ideally for most setups. Too little caster like 2* or less will cause the WJ to become a roller skate and the steering will not come back to center like it should.
NOT THIS:
Originally Posted by BreadsWJ View Post
also rear sway bar, upgrade to Addco if not already done.
waste of money for your specific problem.
WJChris is offline
post #17 of 20 Old 12-20-2011, 09:46 PM
BreadsWJ
Why? If he was all over the road, his rear end could also be an issue.
He didn't specify if the rear was wandering or had tail lag.
My comment is valid. It's a suggestion without actually seeing his rig in person.
---CHECK OUT MY WJ PARTS FOR SALE THREADS ---
"He who seeks knowledge, begins with humbleness" - Anon
BreadsWJ is offline
post #18 of 20 Old 12-20-2011, 10:34 PM
Voltage258
2003 WJ
Ya i have the zone lift and have had no problems yet. I had some death wobble but once i got new tires and an alignment it went away so im not saying it is not something to do with the lift, but my experiance with it is good so far.
03 Grand Cherokee, 4inch Zone lift 15inch craiger soft 8's 31 inch duratracs nothing to special. SOLD
82 Grand Wagoneer Limited. Amc 360, Bridgstone MT's
Voltage258 is offline
post #19 of 20 Old 12-20-2011, 11:13 PM
Hack
2003 WJ
Steering not returning to center is a symptom of alignment issues. So is wandering. I'd bet he has too much toe out. Dial it in and I'll bet it feels much better, and the best part is its free to test out. I'd still get an alignment by a professional though.
Hack is offline
post #20 of 20 Old 12-21-2011, 07:34 AM
WJChris
WJChris's Avatar
The OP already aligned Toe. Caster is the what causes the wheel not to re-center, bad Toe causes PULL and tire wear.
The rear anti-sway bar will only help during cornering to control sway and keep the vehicle level. It will not cover up or alleviate an alignment issue in the front end, nor cure the wheel not returning.
It is not valid for these symptoms. Its a suggestion that will only waste the OP's valuable money, and continue to throw money at the wrong areas.
Many cars do not have a rear sway bar, and they are not "all over the road"
WJChris is offline
Kevins off road? WburtonJ WJ Grand Cherokee Forum 16 09-28-2010 03:43 PM
I need help with my 99 WJ to get it on the road.Please and thank u jeepboy99705 WJ Grand Cherokee Forum 10 09-14-2010 08:27 PM
WJ Road Noise Big_C WJ Grand Cherokee Forum 1 05-11-2010 08:12 PM
What is the best WJ lift for on/off road use ? nierace WJ Grand Cherokee Forum 38 07-31-2007 08:42 AM
