wj all over the road. help now - JeepForum.com
post #1 of 20 Old 12-09-2011, 11:48 PM Thread Starter
98SilverBullet
1994 ZJ
My buddy bought an 04 wj with a 4" zone kit and its all over the road. Lower arm bushings were shot so we put new ones in and that fixed the death wobble, but its still swayin all over.. The steering box had some play so we put a new one in but its still all over. All steering is tight trac bar is adjustable but in good shape. Need help fast plz. Changed steering box and it got tighte steering got tight, like if you turn a corner and let go of the wheel it stay turned.. I'm lost..
94 zl 5.2, np242, d30, trussed, ujoint shafts, all 1\4" wall dom steering, 8.8 trac-loc, disk, custom front/rear bumpers, custom paint, k&n cai, tb spacer, gibson sidepipes. etc etc..
98SilverBullet is offline
post #2 of 20 Old 12-09-2011, 11:59 PM
PhantomWJ
2003 WJ
tie rod ends...
PhantomWJ is offline
post #3 of 20 Old 12-10-2011, 01:11 AM Thread Starter
98SilverBullet
1994 ZJ
I went over them and all is tight
post #4 of 20 Old 12-10-2011, 01:22 AM
ruthole
A 4" zone kit?
94 yj, 4" RC lift 1" shackles, 33's interco M/T's, SRC front bumper, custom built rear bumper, cb, Hi-lift, D30 OX locker, 8.8 LSD,
Lone jeep club member #1
Originally Posted by TMSquy View Post
If parts aint flyin you aint tryin!
ruthole is offline
post #5 of 20 Old 12-10-2011, 01:40 AM Thread Starter
98SilverBullet
1994 ZJ
Yeah looks. To be something like that
post #6 of 20 Old 12-10-2011, 05:56 AM
nickblack
Make sure your axle is centered with the adjustable track bar.
nickblack is offline
post #7 of 20 Old 12-10-2011, 07:37 AM
sinbad85
If you don't have enough caster it will be all over the place, Also if your box is to tight and the steering wheel does not return easy you can loosen the box up a bit.
2001 WJ 4.7L-selec-trac/4.5" Teraflex springs\IRO Long arms\Iro adj rear LCA/Bilstien 5100 series shocks/ IRO steering Equalizer/|265/75/16 Goodyear Dura-Tracs on Stock rims\Rear Tube Bumper with carrier|sliders|mopar skids.
sinbad85 is offline
post #8 of 20 Old 12-10-2011, 11:40 AM
Voltage258
2003 WJ
Are the sway bars connected?
03 Grand Cherokee, 4inch Zone lift 15inch craiger soft 8's 31 inch duratracs nothing to special. SOLD
82 Grand Wagoneer Limited. Amc 360, Bridgstone MT's
Voltage258 is offline
post #9 of 20 Old 12-19-2011, 02:25 PM Thread Starter
98SilverBullet
1994 ZJ
ok **** this jeep..
new 4 balljoints
steering box
lower control arm bushings
adjusted trac bar
tie-rod at pitman is new
adjusted the toe..
still all over the place need help fast.. keep dumping to much money into this thing... oh and steering wont return around corners..
post #10 of 20 Old 12-19-2011, 02:47 PM
Terminator2
Turn wheel and wheel stays turned you need to have the toe, and caster checked. Caster needs to be around 4.5-5.5* ideally for most setups. Too little caster like 2* or less will cause the WJ to become a roller skate and the steering will not come back to center like it should.
Terminator2 is offline
post #11 of 20 Old 12-19-2011, 03:38 PM
skain8
skain8's Avatar
As mentioned -- caster.
Hopefully the zone kit included at a minimum, adjustable uppers. If not, you are SOL.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #12 of 20 Old 12-19-2011, 03:41 PM
AgitatedPancake
Pull your upper control arms and look at the bushings, axle AND frame side. If the jeep has had a rough enough life to destroy lower control arm bushings you have to expect the uppers to be in rough condition.
What does the zone kit do for the rear A-arm and it's balljoint?
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #13 of 20 Old 12-20-2011, 11:27 AM
BreadsWJ
also rear sway bar, upgrade to Addco if not already done.
---CHECK OUT MY WJ PARTS FOR SALE THREADS ---
"He who seeks knowledge, begins with humbleness" - Anon
BreadsWJ is offline
post #14 of 20 Old 12-20-2011, 11:58 AM
Terminator2
I believe the kit has a spacer for the ball joint.
post #15 of 20 Old 12-20-2011, 12:35 PM
TheBandit
I have had to deal with many customers who have the zone kit and have actually talked to zone and the have issues as well without adjustable control arms you can not get enough caster and eventually you will het the death wobble back sorry to say the best thing to do would be a long arm up grade to get the proper caster back in the axel I think iro sells add on long arm kits.... I think
Hope this helps
96 XJ going full widths and all home built
04 WJ Overland Parting Out
TheBandit is offline
Kevins off road? WburtonJ WJ Grand Cherokee Forum 16 09-28-2010 03:43 PM
I need help with my 99 WJ to get it on the road.Please and thank u jeepboy99705 WJ Grand Cherokee Forum 10 09-14-2010 08:27 PM
WJ Road Noise Big_C WJ Grand Cherokee Forum 1 05-11-2010 08:12 PM
What is the best WJ lift for on/off road use ? nierace WJ Grand Cherokee Forum 38 07-31-2007 08:42 AM
