-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   wj all over the road. help now (http://www.jeepforum.com/forum/f310/wj-all-over-road-help-now-1299526/)
98SilverBullet 12-09-2011 11:48 PM
My buddy bought an 04 wj with a 4" zone kit and its all over the road. Lower arm bushings were shot so we put new ones in and that fixed the death wobble, but its still swayin all over.. The steering box had some play so we put a new one in but its still all over. All steering is tight trac bar is adjustable but in good shape. Need help fast plz. Changed steering box and it got tighte steering got tight, like if you turn a corner and let go of the wheel it stay turned.. I'm lost..
PhantomWJ 12-09-2011 11:59 PM
tie rod ends...
98SilverBullet 12-10-2011 01:11 AM
I went over them and all is tight
ruthole 12-10-2011 01:22 AM
A 4" zone kit?
98SilverBullet 12-10-2011 01:40 AM
Yeah looks. To be something like that
nickblack 12-10-2011 05:56 AM
Make sure your axle is centered with the adjustable track bar.
sinbad85 12-10-2011 07:37 AM
If you don't have enough caster it will be all over the place, Also if your box is to tight and the steering wheel does not return easy you can loosen the box up a bit.
Voltage258 12-10-2011 11:40 AM
Are the sway bars connected?
98SilverBullet 12-19-2011 02:25 PM
ok **** this jeep..
new 4 balljoints
steering box
lower control arm bushings
adjusted trac bar
tie-rod at pitman is new
adjusted the toe..
still all over the place need help fast.. keep dumping to much money into this thing... oh and steering wont return around corners..
Terminator2 12-19-2011 02:47 PM
Turn wheel and wheel stays turned you need to have the toe, and caster checked. Caster needs to be around 4.5-5.5* ideally for most setups. Too little caster like 2* or less will cause the WJ to become a roller skate and the steering will not come back to center like it should.
skain8 12-19-2011 03:38 PM
219 Attachment(s)
As mentioned -- caster.
Hopefully the zone kit included at a minimum, adjustable uppers. If not, you are SOL.
AgitatedPancake 12-19-2011 03:41 PM
Pull your upper control arms and look at the bushings, axle AND frame side. If the jeep has had a rough enough life to destroy lower control arm bushings you have to expect the uppers to be in rough condition.
What does the zone kit do for the rear A-arm and it's balljoint?
BreadsWJ 12-20-2011 11:27 AM
also rear sway bar, upgrade to Addco if not already done.
Terminator2 12-20-2011 11:58 AM
I believe the kit has a spacer for the ball joint.
TheBandit 12-20-2011 12:35 PM
I have had to deal with many customers who have the zone kit and have actually talked to zone and the have issues as well without adjustable control arms you can not get enough caster and eventually you will het the death wobble back sorry to say the best thing to do would be a long arm up grade to get the proper caster back in the axel I think iro sells add on long arm kits.... I think
Hope this helps
The time now is 10:52 PM.
