wj ac blower work, yet, no air - JeepForum.com
post #1 of 7 Old 02-06-2014, 07:17 AM Thread Starter
shahav
Hi,
I know there is a common issue with blend door on the limited versions.
But my car is not equipt with multi zone ac.
so what is your suggestion?
My WJ CRD is running 27.1 mpg!
Android Nav software: https://play.google.com/store/apps/details?id=adama.raster&hl=en_GB
shahav is offline
post #2 of 7 Old 02-06-2014, 08:01 PM
William2point0
Have you filled the freon? I thought mine was screwed up. I had it "filled" and it still didn't work. They didn't fill it enough. I had a buddy with refrigeration equipment check it out for me and it needed more. I would start there.
"You needn't die happy when your time comes, but you must die satisfied, for you have lived your life from the beginning to the end and ka is always served." ~SK
William2point0 is offline
post #3 of 7 Old 02-06-2014, 08:25 PM
MuddyWJ
Originally Posted by shahav View Post
Hi,
What is the issue?
MuddyWJ is offline
post #4 of 7 Old 02-06-2014, 11:15 PM Thread Starter
shahav
The issue is in the subject: the fan is working yet no air is coming out. Not in ac mode nor while in heat mode.
Not that the car is not equipt with multi zone.
something is blocking the air. I hope I don't have to disassemble the whole dashboard.
Please advice.
10X
R.
shahav is offline
post #5 of 7 Old 02-06-2014, 11:25 PM
Cirruslydakota
Recirc door is broken. Pull the fan out and feel around in there, it should be loose.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is online now
post #6 of 7 Old 02-06-2014, 11:57 PM
MuddyWJ
X2. Pull glove box off then shine a flashlight up in the upper right hand corner. With the vehicle on press the recirc button and see if the door moves.
MuddyWJ is offline
post #7 of 7 Old 02-19-2014, 09:52 AM Thread Starter
shahav
Just a short update . indeed it was the recircu door.
I fixed in place without taking the dash apart.
Now it is fixed on internal mode only.
I prefer it this way.
Thanx for the diagnosis!!!
Rabin
shahav is offline
