WJ 4x4 Select Trac - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > WJ 4x4 Select Trac
BlackMagicBrakes 7% Discount, Save today!Poison Spyder from CCOR!HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made I
Unread 03-22-2012, 07:47 AM   #1
super98lsc
WJ 4x4 Select Trac
4x4 will engage but its really noisy and if you stop the vehicle in Full Time 4x4 and put both the trans and T-Case in Neutral you cannot roll it, it wont even roll down a hill. Its like a parking brake is on, and it takes a bit of throttle to make it move against its will. Now off road in the mud or loose dirt its not as bad.
All tires same size
I have a bad feeling when the rear-end was replaced after a sideswipe a few years back they may have not installed the correct axle ratios.
Any thoughts?
All shifting mechanisms are in good order and T-case goes through all its ranges as it should. Detents are spot on.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer Limited 360v8/727 ported stock heads,Crane Springs/retainers, Edelbrock RPM Air Gap, Holley HP 750, Crane .497/.522 4" lift 31x10.50 Goodyear Duratrac,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake.
super98lsc is offline   Reply With Quote
Unread 03-22-2012, 11:35 AM   #2
Double E
2000 Laredo V8
Double E's Avatar
Please provide a better description of "noisy".
Squealing? Grinding? Screaming? Moaning? Coughing?
When shifting the TC lever? When in motion?
...the details.
Put Jeep on jack stands & repeat the "e-brake on" symptom. See which wheel(s) is(are) actually preventing motion.
If in the front, remove front DS & see if problem is still there.
Measure axle ratio yourself using the string method.
2000 Laredo 4.7L Selec-Trac. 161K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 2X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X),
new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote
Unread 03-22-2012, 12:44 PM   #3
super98lsc
Noise: Machine like grinding sound like the trans/case is under extreme load very rough.
Ill do the jack stand method and get back with you.
Steering wheel also wants to pull hard to the right when in 4x4 mode on street or dirt.
How do you like the EBC rotors/pads?
Unread 03-22-2012, 03:45 PM   #4
billzcat1
Chicken in a Turkey Suit
2003 WJ
I have a feeling you are absolutely correct here. The transfer case is not making it out of "part time" mode due to the transfer case binding up. If the center differential were unlocked it wouldn't bind up like this. The string technique will work to measure final drive. You can also pop the diff covers and count teeth on the ring/pinion. 3.55:1 is 32 ring, 9 pinion teeth. 3.73 is 41/11.
billzcat1 is offline   Reply With Quote
Unread 03-22-2012, 06:34 PM   #5
robby65
You could also rotate the front wheel one full turn and count how many times the driveshaft rotates if it will turn.
do the same for the rear.
Can you get transfer case in neutral?
robby65 is offline   Reply With Quote
