Quantcast WJ - 4.7 top end off, proven mods - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > WJ - 4.7 top end off, proven mods
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 08-03-2007, 04:14 PM   #1
NoOne2
I have the top end of the motor off and was wondering if there are some proven mods.
HO cams, HO manifold, headers, etc....
Looking for best bang for buck type mods.
No sniffer tests here so are the headers/no cats a good improvement?
Thanks
-- Eric
2000 4.7l Grand Cherokee Laredo
2000 Pewter Corvette
NoOne2 is offline   Reply With Quote
Old 08-03-2007, 04:15 PM   #2
BNB
oh there is plenty of aftermarket for the 4.7...do a full on HCI swap..with a set of headers and high flow cats...300+rwhp you will see fo sho!
[B]2000 Jeep Grand Cherokee Laredo..[/B][I]daily beater[/I]
[B]2006 Mazda 3..[/B][I]zoom zoom[/I]
[B]1980 Corvette L82 Edition..[/B][I]The Blue *****[/I]
BNB is offline   Reply With Quote
Old 08-03-2007, 04:30 PM   #3
NoOne2
HO cams?
I've only found 1 aftermarket cam profile...
What cam/header/intake combo will get me 300? Thats whp too? Thats probably about 350-360 at the crank.
Many have probably not found 4 wheel dyno's but any of those numbers proven either by track improvements for actual dyno numbers?
Require premium? Idle and driveability quality?
-- Eric
Old 08-03-2007, 04:36 PM   #4
BNB
contact Crane,lunati,or hell even Mopar Performance cams..they should have an aftermarket cam for the 4.7...
and yes the HCI swap would put you in the 300+rwhp range..
and tuned right you can run on regular pump gas..but that is a proper tune by someone..while running a full ingnition system...and a damn good fuel system...it can go on and on...just a matter of what exactly you want to do and budget..
Old 08-03-2007, 04:41 PM   #5
RyanZJ
http://www.jeepsunlimited.com/forums/showthread.php?t=626553
Is that a banable offense?
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline   Reply With Quote
Old 08-03-2007, 04:42 PM   #6
NoOne2
Thanks...I'm used to LS1 stuff and there are so many 'recipes' for different HP levels, its a lot tougher to find 4.7 stuff.
Tuning isn't a problem but do most run aftermarket ECU's or just ignition systems?
There was a company I found, K something or other, can't find them again...had a few cam profiles available but I'm looking to replicate something that worked for someone else, something I know works.
-- Eric
Old 08-03-2007, 04:45 PM   #7
RyanZJ
Sounds like you're thinking of KRC for the cams.
Most people use the existing ECU and add a Mopar chip or something equivalent and just upgrade the ignition system.
Nick at kolak@aol.com might be a good person to ask about all of this as well.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
Glock Forum
