WJ 4.7 P0340 and P1391 - JeepForum.com
post #1 of 4 Old 05-23-2014, 11:25 AM Thread Starter
MountainMan303
Hi there,
Listen, I have looked into this plenty on the interwebs and am currently just looking for a quick solution/advice from someone who might have had the same problem. I completely understand that this topic has been covered hundreds of times, but I can't find a concrete solution, as this seems to be a complicated issue.
After replacing my girlfriend's crankshaft positioning sensor (Mopar from dealership) over the weekend because of no-starts and stalling issues, her '99 4.7 WJ ran fine for about a day. Now it's throwing P0340 and P1391 codes at me, indicating that something is going wrong with either the CMP or CKP. My only solution right now is to try a camshaft position sensor, and hope that fixes the problem.
Anyone have the same issue, or any advice for me?
1995 ZJ Grand Cherokee 4.0L, 3.5" Iron-Rock Benchmark kit, 31x10.5x15 Duratracs, 15x8 Cragar Soft 8's, Front and Rear Adjustable Tracks, Up-Country Skids
MountainMan303 is offline
post #2 of 4 Old 05-23-2014, 02:59 PM Thread Starter
MountainMan303
Can anyone help me with this before the dealership parts store closes today???
post #3 of 4 Old 06-09-2014, 04:26 PM
limitmike
I have had the same issues. Your best bet is whenever one CMP or CKP goes out replace the other with it and you should be good to go.
limitmike is offline
post #4 of 4 Old 06-09-2014, 05:23 PM
miami5th
I had a failed camshaft position sensor. The jeep would crank and turn over but never fully start. I replaced the CPS with a MOPAR sensor and it fixed the problem a well as the code. The installation was pretty straight forward. CPS is somewhat underneath the battery tray, in that general area.
I had a thread going about CPS removal/reinstall. That thread even has pics. http://www.jeepforum.com/forum/f310/...p0340-1502345/
Hope that helps!
miami5th is offline
