WJ 4.0l bottom end - Page 3 - JeepForum.com
post #31 of 64 Old 07-28-2014, 03:23 PM Thread Starter
Swiff
Rods and Pistons assembled Thanks to B&B machine shop in Oceanside N.Y.
Now I just need to find time to put it back together.
Hope I remember where all the bolts go
Derek
2k JGC Laredo WJ - 4.0L - 42RE - Select-Trac 242 - 3.55 -
Swiff is offline
post #32 of 64 Old 07-28-2014, 06:52 PM
ChrisHager
Administrator
ChrisHager's Avatar
Any bolt left over is more power via weight reduction.
All kidding aside, no matter how careful I am and how precise I label everything, I darn near always have one or two random fasteners left over that makes me think, "where the heck do you go??!".
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #33 of 64 Old 07-28-2014, 08:10 PM Thread Starter
Swiff
I usually have problems with my tools. I would put down a wrench or socket and then spend like 2 hours looking for where I put it.
I wish I could put that in my signature.
Derek
Swiff is offline
post #34 of 64 Old 07-28-2014, 09:08 PM
gold01wj
Story of my dang life! Glad your getting it all back together. Sounds like you are like me and enjoy going thru your rig and knowing every nut and bolt. Good luck with it. The Initial startup is always the most intense for me.
2000 wj limited quadradrive 4.7 family vehicle-was stock, then lifted 4",now stock again
gold01wj is offline
post #35 of 64 Old 08-02-2014, 09:30 PM
jeepyard
LOL, I could cut all my mechanic job's time in half if I could keep up with my tools!! Pay's to have extra's especially the most popular size's!!
jeepyard is offline
post #36 of 64 Old 08-03-2014, 01:22 PM Thread Starter
Swiff
While cleaning up the mating surfaces for the oil pan I saw the timing chain and it has way too much play. I am surprised It did not jump a tooth.
Well back to ordering parts. Timing chain and 12 pushrods on order from Summit.
Derek
Swiff is offline
post #37 of 64 Old 08-03-2014, 02:43 PM
ChrisHager
Administrator
ChrisHager's Avatar
I'd buy the sprockets as well. They aren't too expensive and pair well with a new chain.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #38 of 64 Old 08-04-2014, 09:18 PM Thread Starter
Swiff
I inspected the sprockets today and they have virtually no wear on them. So I opted not to order them.
Derek
Swiff is offline
post #39 of 64 Old 08-04-2014, 10:00 PM Thread Starter
Swiff
Ok some pics for the disassembled the motor.
The air filter housing
Electric fan
Valve cover
Harness
Water pump
Derek
Swiff is offline
post #40 of 64 Old 08-04-2014, 10:13 PM Thread Starter
Swiff
Intake / Exhaust manifold
Getting ready to hone cylinders
Didn't get to finish them . Forgot to charge the batteries.
Pulled crank pulley
Removing front cover bolts /Crank pulley came out without a fight.
Damper still looks good
Derek
Swiff is offline
post #41 of 64 Old 08-04-2014, 10:18 PM Thread Starter
Swiff
Front cover bolts out
When I removed the timing chain cover the guide was broken.
Lucky that is on order already.
I am also waiting for timing cover gaskets and seal.
Derek
Swiff is offline
post #42 of 64 Old 08-04-2014, 10:19 PM Thread Starter
Swiff
The hone was also chipped so I will get another and finish up.
Derek
Swiff is offline
post #43 of 64 Old 08-05-2014, 07:50 PM Thread Starter
Swiff
More new parts
Water pump water outlet pipe and timing chain
Timing chain cover gasket set
Derek
Swiff is offline
post #44 of 64 Old 08-05-2014, 07:54 PM Thread Starter
Swiff
Pushrods on 2 week back order
Derek
Swiff is offline
post #45 of 64 Old 08-05-2014, 11:18 PM
Cirruslydakota
Is that the doorman water pipe for the heater hose? I ordered one when I did my water pump and it was too short. Put my old rusty one back on and it fit perfectly.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
