WJ 4.0l bottom end - JeepForum.com
post #1 of 64 Old 07-08-2014, 02:48 AM Thread Starter
Swiff
WJ 4.0l bottom end
Well the JGC is down for repairs. I was hearing a pretty loud tick on the way home so I pulled the valve cover and checked the push rods and upper valve train. I even held each push rod while vehicle was running and no difference in sound. The next step was to drop the oil pan. So I did and found piece of a piston skirt in there. It was from the #6 cylinder. Well I checked the bore and no signs of damage. Guess it's time to take her apart. 187k miles. Gotta find torque specs., and a decent 12pt. 13mm deep impact socket for the head bolts. Wish me luck.
Derek
2k JGC Laredo WJ - 4.0L - 42RE - Select-Trac 242 - 3.55 -
Swiff is offline
post #2 of 64 Old 07-08-2014, 02:51 AM Thread Starter
Swiff
Oh and a place that sells parts for a reasonable price. ie pistons, rods, rings, bearings, gasket set and head bolts.
Derek
Swiff is offline
post #3 of 64 Old 07-08-2014, 08:18 AM
ChrisHager
Administrator
ChrisHager's Avatar
WJ Torque Specs - Complete List
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #4 of 64 Old 07-08-2014, 11:04 AM
StrokedWJ
StrokedWJ's Avatar
I have used Summit Racing, Falcon Global (ebay seller, but call phone # to order specific parts), and of course rock auto to source parts for my 2 engine builds. Would recommend and use all 3 again.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #5 of 64 Old 07-08-2014, 12:32 PM
msweet2111
I used rock auto for all the parts related to my rebuild... Couldn't beat their prices
01 WJ, freshly built 4.0, 3" lift on 31's, custom winch bumper, intake/exhaust, discos
msweet2111 is offline
post #6 of 64 Old 07-08-2014, 10:39 PM Thread Starter
Swiff
I pulled the head off and pushed the pistons out today. only #6 piston skirt was broken. The cylinders are all clean and shiny and the crank has no marks. Thanks for the link to the torque specs ChrisHager, they will come in handy. My rods have the stamped #691 on them. Well time to look at these companies to see who has the right piston and rod set for me. There are a couple of different ring thickness for the pistons. Is there a difference. Time for some more research.
Derek
Swiff is offline
post #7 of 64 Old 07-09-2014, 12:06 AM
jetrinka
Shouldn't be ring thickness. Those measurements of the new rings are how oversized you want them. Standard is for a standard bore and they usually go up in .020" increments determined by how much you would bore the cylinders out in a complete rebuild. If you are positive the motor has never been completely gone through, just order the standard size rings and pistons. If you have any doubt, measure the bores and compare them to what they should be stock and order rings accordingly. The same thing with big end of the rod and crank journals for rod bearing sizes.
jetrinka is offline
post #8 of 64 Old 07-09-2014, 12:12 AM
grussell
I used Sealed Power pistons and rings on both of my rebuilds. They have the thicker skirts. I bought them through the machine shop that bored my blocks and I had them install new camshaft bearings in both blocks. The wristpins have to be pressed out and pressed back into the rods. I had them do that too. Is the rod damaged? The machine shop redid my rod journals too.
2001 GC Laredo 4.0 4x4 - Black l 2001 GC Laredo 4.0 4x4 - Silver
grussell is offline
post #9 of 64 Old 07-09-2014, 04:44 PM
jeepyard
Northern Auto Parts also has great prices on engine parts, On my last 4.0 I got alot of my parts from them.
jeepyard is offline
post #10 of 64 Old 07-10-2014, 12:54 AM Thread Starter
Swiff
So sealed power makes 2 different pistons for apparently the same application. Sealed power H802CP or H825CP should be a exact replacement for the piston that I was looking for. But it depended on the size of the rings I have. Its just the regular cast hypereutectic piston. On the H802CP, ring 1 and 2 is 1.5mm and ring 3 (oil ring) is 4.0 mm. On the H825CP, ring 1 and 2 is 5/64 and ring 3 (oil ring) is 3/16. One is standard and one is metric. That's just how it is listed. I had to look for the part number on the inside of my piston and the H802CP is a cross reference of 53020507. The H825CP is a cross reference of 4798329. Mine happened to be 53020507. Hopes this helps someone out in the future.
Derek
Swiff is offline
post #11 of 64 Old 07-10-2014, 08:44 AM
StrokedWJ
StrokedWJ's Avatar
The late model 4.0's (WJ's) use the metric ring sets.
post #12 of 64 Old 07-10-2014, 12:35 PM Thread Starter
Swiff
I think that I will order most of my stuff from summit. They at least give you specs on what you are ordering.
Derek
Swiff is offline
post #13 of 64 Old 07-11-2014, 05:06 AM Thread Starter
Swiff
Well all parts ordered. Now it's just a waiting game.
Derek
Swiff is offline
post #14 of 64 Old 07-12-2014, 03:39 PM
Riley/MN
Watching the thread... XJ guy here but I just pulled the pistons out of a 99 WJ we bought for my wife. The cylinders were not bad (Did a quick hone and they look okay), but the piston skirts were pretty scuffed up. I am thinking of just putting in a new set, since I am here... The Jeep had a terrible knock when we bought it...
I pulled all the rod caps off and the bearings in them looked fine, but when I pulled the pistons out, the top half of the bearing in every rod was showing copper.... so I will put in a set of rod bearings.
The bottom half of all the main bearings looked fine, but I think that as long as I am here (& since I couldn't check the top half of the bearings), I will do the main bearings & rear main seal as well.
Who do you guys like for bearings & gaskets? I know rock auto has 'em, but are there brands to stay away from? Which brands offer the best value?
Thanks
~Riley
TMA MN State Rep
http://www.traditionalmuzzleloadingassociation.com
Riley/MN is offline
post #15 of 64 Old 07-12-2014, 04:15 PM
jeepyard
I like clevite or federal mogal for bearings. Victor gaskets work but fel pro is best.
jeepyard is offline
