wj 4.0 a/c problems - JeepForum.com
post #1 of 7 Old 07-13-2010, 12:44 AM Thread Starter
msn636
2003 WJ
wj 4.0 a/c problems
So it holds pressure but it just wont blow cold. It hisses when i accellerate and gets even warmer. Compressor seems to be working but the electric fan doesnt ever kick on. Could that be part of it? If so how come it wont? I straight wired it and the fan works. Relay is good and i replaced the temp sensor. Im stumped and its too dang hot in Texas.
msn636 is offline
post #2 of 7 Old 07-13-2010, 12:13 PM
rgulley
Are you saying the Ac blower motor in the dash is the one you straight wired?
rgulley is offline
post #3 of 7 Old 07-13-2010, 04:48 PM Thread Starter
msn636
2003 WJ
No, sorry. Its the electric fan behind the radiator. I didnt know if it could be related to my a/c problems. Either way, i check the pressure and it reads between 40 and 50. Still blows warm.
msn636 is offline
post #4 of 7 Old 07-13-2010, 09:39 PM
rgulley
The fan behind the radiator will cycle on and off at times and really doesnt have any direct relation to the ac. 40/50 sounds good, is the compressor running? Is the gage jumping?
rgulley is offline
post #5 of 7 Old 07-13-2010, 10:10 PM
SplitNail
That fan needs to be on when the AC is on to remove the heat from the AC. The air blows over the condensor to remove the heater from the air. If the fan isnt coming on then the pressure if building in the lines and the pressure cycle switch is tell the compressor to turn off, in return its blowing hot air.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #6 of 7 Old 07-13-2010, 10:27 PM
rgulley
Here Is a diagram that better explains how it works.
rgulley is offline
post #7 of 7 Old 07-13-2010, 11:09 PM Thread Starter
msn636
2003 WJ
The gage isnt jumping. But the fan never comes on. Ive had it idleing for 15 minutes and nothing. But the coolant temp is good. And the compressor comes on. So why isnt my elec fan coming on at all?
msn636 is offline
Mudding problems.....What do you guys do to prevent problems? JackAysJake ZJ Grand Cherokee Forum 8 02-23-2009 09:02 PM
cb problems blk418 WK Grand Cherokee & XK Commander Forum 5 06-02-2007 03:05 PM
Alternator problems??? Shock problems??? rflem550 ZJ Grand Cherokee Forum 11 01-24-2007 06:41 AM
AC problems cy0013 ZJ Grand Cherokee Forum 2 06-21-2005 01:39 PM
4 low problems Billybot7 WJ Grand Cherokee Forum 2 01-27-2004 01:57 PM
