WJ 3" Lift - Tire size? - JeepForum.com
 1Likes
  • 1 Post By ChrisHager
post #1 of 8 Old 08-18-2017, 11:15 AM Thread Starter
SEBlackonBlack
Ok, now I'm ready to lift it. I got some great advice with tires on this forum before the lift.
I plan on lifting my GC 3 inches. I wanna keep the same rims. 18x8 WKIIs show in the photo. So what size tires will fit after the lift. If it rubs a little Ill be fine with trimming.
Also do you guys have any photo examples of your GC lifted 3 inches so I can get an idea of stance?
SEBlackonBlack is offline
post #2 of 8 Old 08-18-2017, 12:23 PM Thread Starter
SEBlackonBlack
side note - all terrain mud tread preferably.
post #3 of 8 Old 08-18-2017, 01:05 PM
ChrisHager
Administrator
ChrisHager's Avatar
DuraTracs can be had in a 265/60R18... I think their 265/65R18 may be too much. 18" wheels kind of limit your A/T or M/T options.
SEBlackonBlack likes this.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 8 Old 08-18-2017, 01:20 PM Thread Starter
SEBlackonBlack
Thats actually a sweet looking tire. if you think 256/60R18 would be good on the 3 inch lift, ill roll with that. you gave great advice last time bro. Thx again
post #5 of 8 Old 08-18-2017, 01:27 PM
ChrisHager
Administrator
ChrisHager's Avatar
It's a really good tire for all sorts of weather and it performs quite well off-road. It's one of the few AT/MT hybrids.
I always like a 245/75R16 on a 2-3" lift. It looks good but also allows you to use the tire off-road and disconnected. You CAN squeeze in a bit more tire but knowing your flex limit would be accidentally curb hopping in the parking lot is a bit unnerving in my opinion.
A 265/60R18 is pretty much the same height as a 245/75R16 (30.5") and a bit wider at 10.5". Typically, I prefer thinner over wider but hey, it's what's inside that counts.
Wait, we're talking tires. 10.5" wide tires aren't overly wide at all, though the extra width on a 30.5" tall tire will increase you chance to rub. Also, if you ever throw on wheel spacers, you may increase rubbing as well.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #6 of 8 Old 08-20-2017, 02:39 PM
Nuttydave
2003 WJ
3" IRO lift with 265/70r17s.
They do rub in full lock and partial on inner fender plastic. Not entirely sure about full flex as pavement princess.
http://i.imgur.com/vMVj0Bd.jpg
Nuttydave is offline
post #7 of 8 Old 08-20-2017, 11:39 PM
Kolak
Vendor
Kolak's Avatar
32" diameter tires of up to 265 width are very common for 3" of lift. You will have to trim a little plastic on the front bumper cover. A 31" tire shouldn't rub at all.
When you choose a tire, be cautious about the sidewall load range rating. Stay away from load range E as they will be too stiff and make the ride harsh. Load range C is ideal.
I'm an IRO dealer and an Old Man Emu dealer and would be happy to assist with a lift. You can PM me here on the forum or email me at kolak@aol.com and we'll chat
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #8 of 8 Old 08-21-2017, 05:05 AM
coldspit47
Junior Member
I run 265/75/16 on my 3in IRO. Had to trim just over an inch on the front bumper and rubs the left LCA at full left lock. Mine are Laufenn X Fit A/T (Hankook's cheaper line).
Ignore the bumper rash and the lack of tire shine on the rear...this was several days after getting it cleaned.
baby jeep: 04 WJ Laredo w/ 242, IRO 3in w/ bilsteins & adj trackbar, IRO adj short front/rear UCA/LCA/A arm, 265/75/16 Laufenn Xfit, 4.56 gears
coldspit47 is offline
