WJ 3 inch lift and 33s - JeepForum.com
post #1 of 14 Old 06-10-2012, 04:22 PM Thread Starter
DrGrand
2003 WJ
Wj WJ 3 inch lift and 33s
Is it possible to run 33s on a WJ with a 3 inch lift? I have 31s now, and they just don't cut it. I know with an IRO 4 inch lift, you can run 285/75r16s. Is it possible ro run this size or a 33x12.50 on a 3 inch lift?
03 WJ, 7.25", Custom LAs, 35s, Spooled HP44, Locked D60, 5.13s
DrGrand is offline
post #2 of 14 Old 06-10-2012, 04:32 PM
metalhead
2011 WK
No way you can run 33's on a 3 inch lift without a whole hell of a lot of cutting. I have 31's on a 3 inch lift and I had to trim a little plus add 1 inch spacers so the tires would not rub on the lower control arms.
metalhead is offline
post #3 of 14 Old 06-10-2012, 06:20 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Just keep cutting until it fits.
~Richard
billzcat1 is offline
post #4 of 14 Old 06-10-2012, 07:02 PM
PhantomWJ
2003 WJ
There is a noob lift chart some where on here....
Did you try googling it? How about going over the threads?
As mentioned above, you can fit 33" tires on a 3" lift, if you want...just keep cutting.
PhantomWJ is offline
post #5 of 14 Old 06-11-2012, 12:20 AM
MWyatt
I have the IRO 3" with 31s and just cut my fenders and have plenty of room for 33s now.
'99 4.0 - IRO 3" Lift, 31s, JCR Stage 3 Sliders, KOR 3/4" Spacers, Thrush Welded Muffler, Cut Fenders
you can't fix it with a hammer, then you have an electrical problem."
MWyatt is offline
post #6 of 14 Old 06-11-2012, 04:34 PM Thread Starter
DrGrand
2003 WJ
That is the direction that I was wanting to go. I may grab some Icelandic Offroad fenders. Those will make room for 33s for sure
DrGrand is offline
post #7 of 14 Old 06-11-2012, 04:59 PM
D0dgeRam1500
Bushwacker is still working on fender flares for the WJ. Here is a link to their Facebook album. https://www.facebook.com/media/set/?...3781796&type=3
2005 Jeep Wrangler Willys Edition
D0dgeRam1500 is offline
post #8 of 14 Old 06-11-2012, 05:09 PM
PhantomWJ
2003 WJ
You may find yourself waiting a while for those fenders..
post #9 of 14 Old 06-11-2012, 05:15 PM
adavis39
theres a difference between getting them to fit sitting in your driveway and getting them to fit when you are disconnected and fully flexed off road. 33's on a 3'' lift will require a ton of trimming and will limit your ability to stuff that tire into the wheel well...jmo
2002 WJ Limited 4.7: 6" Clayton REALLY long arms....yep, they are longer than yours SOLD : (
1998 Platinum 5.9 DD
2007 WK Overland 5.7 wifes DD
TNJEEPS.COM
BUILD:
"In a world that he did not create, but he will go through it as if it is his own creation. Half man, half beast, whatever it is it is weird, it is ticked off and it calls itself Slash"
adavis39 is offline
post #10 of 14 Old 06-11-2012, 05:31 PM
D0dgeRam1500
I would try 4 inches of lift and 33's. The Bushwacker flares will be out at some point this year.
post #11 of 14 Old 06-11-2012, 05:36 PM
adavis39
i have not seen them in person but a guy posted on here that saw the bushwackers out in MOAB and his desription was that they have more lateral coverage than vertical clearance. Im iffy on how useful they will be until I see them in person. id go at least 4'' for 33's and be prepared to cut
TNJEEPS.COM
BUILD:
adavis39 is offline
post #12 of 14 Old 06-12-2012, 09:59 PM
99RubiconWJ
i have 3" of lift and am running 32" tires with no trimming or rubbing
99RubiconWJ is offline
post #13 of 14 Old 06-12-2012, 10:02 PM
Dean-
do it and trim
99' WJ Limited- 4' IRO Lift, 32' BFG's on Moabs....
Dean- is offline
post #14 of 14 Old 06-13-2012, 10:04 AM
JeepAMG
I have 275/55/20 and a 3" inch lift. Just had to enjoy a bit of trimming and everything worked fine
JeepAMG is offline
6 inch lift with 2 inch BB 240impala WJ Grand Cherokee Forum 8 03-29-2012 11:28 PM
4 inch lift ?s ablaydes WJ Grand Cherokee Forum 15 01-29-2012 08:01 PM
A 4 inch suspention lift and a 2 inch body lift. Could that suport 36inch tires? Calpatt WJ Grand Cherokee Forum 27 04-26-2011 05:17 PM
3 inch lift with 265/75/16?? XJ57 WJ Grand Cherokee Forum 21 02-21-2011 05:36 PM
4 inch teraflex lift vs IRO 4inch lift??????? anden02 WJ Grand Cherokee Forum 50 11-01-2010 10:46 AM
