Wj 247 to 242 t case swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Wj 247 to 242 t case swap
New! JK/U skid plate system.We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!
Unread Yesterday, 12:58 AM   #1
Vjeeps
Hey all. I'm taking the 247 transfer case out of my 2002 V8 Wj and putting in a 242 transfer case out of a ZJ. Will I need a new front or rear drive shaft? And is there anything else I will need? Thanks in advanced!
Vjeeps is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:24 AM   #2
AsainWithJeep
Your best bet would have been to pick up both front and rear driveshafts of the WJ you got the tcase from... "Search" the Forum for 242 swap or 242 conversion... you'll find DOZENS of threads about this particular topic. Trust me. Do your research, you'll find everything you'll need. That's exactly what i did. I'm in the process of doing a 4.5" short-arm lift as well as a 242Hd conversion on my V8 WJ. All the info is out there man
AsainWithJeep is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:39 AM   #3
AsainWithJeep
If you're lifting, you'll want a double-cardin style front driveshaft. If not, you should be fine, at stock height, with a double-repezza. Count the splines n the output shaft of the tcase, i know the 247 had a 27-spline output shaft. I do NOT know if the V8 ZJ's had 32 or 27 spline output shafts on their tcases. I know the I6 ZJ's had 27. So guys question the strength and reliability of an I6 tcase swapped into a V8. The thickness of an I6 tcase chain vs a V8 tcase chain is noticeable, very noticeable. Enough so that i ditched the idea of doing this exact same swap in my WJ and sourced a 242HD from a junk yard 2.5hrs away. I would advise "rebuilding" it too, before installing it. You'll want to check to see if there is any wear on any of the internals, chewed gears/teeth, and if the plastic pads on the shift forks are still intact. and run a magnet through the fluid to see if there are any shavings floating around (Tore my ZJ 242 apart that i was going to swap in, and all but one plastic pads was completely destroyed. There was so much rubbing on the internals of this tcase that the one fork is utterly useless.) there's a good bit you may want to look at really. I'd also suggest that, since you're going to be dropping the driveshafts anyway, install new u-joints on both front and rear driveshafts.
Unread Today, 12:28 AM   #4
Vjeeps
How can I replace the U joints? If I'm not mistaken these drive shafts have non replaceable u joints.
Unread Today, 05:42 AM   #5
Highschool_WJ
You are mistaken, you can rebuild or replace all the u joints (or cv joints depending on which front driveshaft you have) on both the front and rear shafts.
,,,soooo I graduated in 2013...
Highschool_WJ is offline   Reply With Quote Quick reply to this message
