WJ 2002 Rear Main Seal Oil Leak - Page 2 - JeepForum.com
post #16 of 21 Old 01-12-2011, 03:40 PM Thread Starter
Aggieneer2006
The Oil Pressure Sending unit...What is it exactly? What breaks? The unit itself or some more o-rings? If it is not too expensive I might as well switch it out too...
Aggieneer2006 is offline
post #17 of 21 Old 01-12-2011, 04:46 PM
MStaffin
I used a thicker oil cause my 00 4.0 the rear main seal is leaking. I think they are all one piece. You can add the lucas or some other product to try and stop it for a little or slow it down.
MStaffin is offline
post #18 of 21 Old 01-12-2011, 08:35 PM
Twospeed
Looks like this but is screwed into the block and has a connector going on it. The diaphram inside fails and oil is pushed through it. No o-rings, just replacement.
"Driver has no money, he owns a jeep."
Twospeed is offline
post #19 of 21 Old 01-16-2011, 07:20 AM Thread Starter
Aggieneer2006
So yesterday I went to the the dealer to get the "3 piece o-ring" kit and apparently the WJ (1999-2004) Jeep does not have use this anymore. I asked to see the oil pressure sender too and it did not have an o-ring on it either so I have ruled these two things out. I changed the oil and once again it seems to be coming from above the filter area. The seal around the oil filter is fine and dry....It might be the valve cover gaskets. I will try this next weekend.
post #20 of 21 Old 01-16-2011, 07:25 AM Thread Starter
Aggieneer2006
Thanks Two speed. Okay I just read your diaphragm failure post. I saw it above the filter. It was $54 at the dealer. I asked to see it but since it didn't have an o-ring on it I figured it was not the problem. I guess I can switch this out before I change out the valve cover gaskets. I hope it works.
post #21 of 21 Old 01-16-2011, 10:13 AM
Twospeed
If you change the sending unit, clean the connector with some electrical connection cleaner before you re-connect it. Otherwise you may get some funky oil pressure readings due to a bad connection.
Twospeed is offline
2002 , grand cherokee , oil leak , rear main seal , v8
Rear Main Seal Leak, Front Diff Seal Leak, Valve cover leak. willcherokeexj XJ Cherokee Technical Forum 48 03-16-2010 01:55 PM
Oil Leak . . Rear Main Seal? Efekt98XJ XJ Cherokee Technical Forum 10 03-26-2009 04:53 PM
How bad can I let a Rear Main Seal leak get? photonut13 XJ Cherokee Technical Forum 14 04-13-2008 10:42 AM
rear main seal leak 70ssclone XJ Cherokee Technical Forum 8 11-23-2006 01:04 AM
Rear main seal leak!!! Dvs_Lance XJ Cherokee Technical Forum 12 03-14-2005 10:00 PM
