WJ 2002 Rear Main Seal Oil Leak - JeepForum.com
post #1 of 21 Old 01-06-2011, 01:07 PM Thread Starter
Aggieneer2006
Before I start, I want to mention that the problem is with a 2002 Jeep Grand Cherokee, Limited (WJ) 4.7 V8 Quadra-Drive. I have searched through the forum and have not found anyone addressing this problem. Plenty of older and newer models with the "two-part" seal fix...but not anyone talking about it for the WJ.
Well my oil is leaking about 1 qt every 3,000 miles. I am 80% sure it is my rear main seal. I did a visual inspection of the valve cover but couldn't see anything. Anyway, I am just doing some research on what it will take to change out this seal. I am mechanically inclined and have done almost all the repairs on this Jeep myself.
So far I know it is a one piece seal. I talked to the service men at the dealer and he says you have to drop the transmission. They say anywhere between 6-8 hours.
So any advice, how-to's, experiences? Please tell me if this should be left to the pros or if you think I can do it myself?
Thanks,
Jose
Aggieneer2006 is offline
post #2 of 21 Old 01-06-2011, 01:16 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
you haven't found anything in this forum section because it's for XJ cherokees.
This forum is specific to WJ owners - you'll be able to find a better answer there:
http://www.jeepforum.com/forum/f310/
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #3 of 21 Old 01-06-2011, 03:32 PM
98_XJ
From reading in here (XJ) I know if it is a one piece you have to drop the transmission.
1998 Jeep XJ Limited 4x4
- Rough Country Series II 3" Lift
- 31-10.50-15 Duratracs on Black Rocks
- JCR Offroad Stage 3 Front Bumper
2010 Chevy Equinox
98_XJ is offline
post #4 of 21 Old 01-06-2011, 04:25 PM
nickblack
All 1 piece rear main seals require separation of the engine & transmission.
nickblack is offline
post #5 of 21 Old 01-06-2011, 04:44 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Yup gotta pull the engine or drop the tranny on the 4.7.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #6 of 21 Old 01-06-2011, 06:35 PM
Merc1973
Just curious, How many miles do you have? Good luck!
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #7 of 21 Old 01-07-2011, 08:39 AM Thread Starter
Aggieneer2006
Thanks Guys. Sounds like I should let a pro do it. I have 140,000 miles on it. I thought this was a WJ forum...Not XJ....not sure what you are talking about duckie564...
Has anyone tried doing it yourself?
post #8 of 21 Old 01-07-2011, 08:45 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Pulling the tranny on a WJ is not too hard, at least I think.
post #9 of 21 Old 01-07-2011, 09:28 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
The thread got moved by the admins
dukie564 is offline
post #10 of 21 Old 01-07-2011, 09:31 AM
SplitNail
Aggieneer2006 where are you at in houston? I'm in Katy.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #11 of 21 Old 01-08-2011, 05:43 PM Thread Starter
Aggieneer2006
I'm around Reliant stadium. Changing the oil on my ride tommorow. I will make a better inspection.
post #12 of 21 Old 01-11-2011, 10:12 AM Thread Starter
Aggieneer2006
Just an update. I was going to do an oil change as well as inspect the underside of my Jeep to look for the leak. I wiped everything down as everything is wet...I noticed that the oil filter would develop droplets of oil! I researched that and found that it may be some O-rings from the oil filter adapter. I will do that this weekend.
post #13 of 21 Old 01-11-2011, 10:35 AM
Twospeed
If it's from that area, check the Oil Pressure Sending unit also. It's right above the oil filter and leaks like mad when it breaks. Ask me how I know.
Twospeed is offline
post #14 of 21 Old 01-11-2011, 10:40 AM
SplitNail
Ask me how I know too. I broke mine off in the block..... That was a BLAST!!
post #15 of 21 Old 01-11-2011, 10:41 AM
SplitNail
Thats pretty far from me. I actually go to A&M. lol Whoop!
2002 , grand cherokee , oil leak , rear main seal , v8
Rear Main Seal Leak, Front Diff Seal Leak, Valve cover leak. willcherokeexj XJ Cherokee Technical Forum 48 03-16-2010 01:55 PM
Oil Leak . . Rear Main Seal? Efekt98XJ XJ Cherokee Technical Forum 10 03-26-2009 04:53 PM
How bad can I let a Rear Main Seal leak get? photonut13 XJ Cherokee Technical Forum 14 04-13-2008 10:42 AM
rear main seal leak 70ssclone XJ Cherokee Technical Forum 8 11-23-2006 01:04 AM
Rear main seal leak!!! Dvs_Lance XJ Cherokee Technical Forum 12 03-14-2005 10:00 PM
