wj 2001 death wobble problem!!!:( - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > wj 2001 death wobble problem!!!:(
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 12-18-2009, 09:06 AM   #1
Jean_WJ
hello friends I have 6 months trying to fix my problem with death wobble ... my wj has a 6.5''lift rockkrawler, trackbar IRO rigth hand drive 3-8", pitman arm 1"... tow stering stabilizer... one in the stock position and one for the trackbar drackline attached ... the death wobble hard to fix it ... but still has death wobble slight movements that are quite in wheel ...I could offer solutions ...... thanks.
I apologize for my English... thanks for your answers!!
Jean_WJ is offline   Reply With Quote
Unread 12-18-2009, 09:09 AM   #2
Bstd_02_wgn
Check your alignment and balance first, make sure those are on. Death wobble can be caused by bad bushings in LCA's/UCA's, bad track bar bushings, heck....pretty much anything in the front end. Make yourself a checklist and jack up the vehicle by the frame and use a prybar to start manipulating things. check for large amounts of movement and replace the parts as necessary. Sry I cant be much help, but there is just too many things that can be associated with death wobble.
2000 XJ: HP30, 8.25 w/ 4.56 gears, Lockrite and Detroit, rear disc swap, WJ knuckles/draglink/tierod/brakes, AA SYE, 35" MTr's w/ Kevlar, Homebrew hand throttle, RE 7.5" Short Arm Lift, Durango box, fitchVA fuse box & switch box w/ OEM green Contura switches, Limited tan leather seats & console, KC HiLites on roof rack, ZJ ARB bumper w/ M8000 winch, Cragar Soft 8 wheels, TJ flares, full stereo upgrade, on & on & on
Bstd_02_wgn is offline   Reply With Quote
Unread 12-19-2009, 05:33 AM   #3
SENECA
I have the IRO 6.5" citical path lift and that itself got rid of my problem with death wobble I had prior when I had a 2" BB lift.I also put a large drop pitman arm.
http://rustysoffroad.com/mm5/merchan...egory_Code=ste
The mechanic that works on my WJ said this pitman arm was important to solving the DW problems I had.
SENECA is offline   Reply With Quote
Unread 12-19-2009, 08:22 AM   #4
skain8
He was wrong.
'02 WJ: 4.7L, 5", 44/9, 231HD w/SYE, 35's, Clayton's
'99 XJ: stock
'98 XJ: stolen
231HD build guide
skain8 is offline   Reply With Quote
Unread 12-19-2009, 09:41 AM   #5
SENECA
Well he was right in that it DID SOLVE the DW problem "I" had.He wasnt speaking about anyone elses.
This was the last thing he tried after a year or two of dealing with it (new tires,alignment,bushinges,Kevins DW eliminator shocks,etc,etc,) and I have had absolutely NO death wobble in almost 2 + years now.
Go figure.
Unread 12-19-2009, 11:26 AM   #6
skain8
Unless you and your mechanic confused bumpsteer for DW, a new drop pitman arm did not fix, cure, or have anything to do with your DW. Only exception being that you replaced the pitman arm rod end while you were at it and it was worn.
'99 XJ: stock
'98 XJ: stolen
231HD build guide
Unread 01-14-2010, 12:51 PM   #7
Jean_WJ
hello my problem with DW continuous change all the bushings control arms upper and lower, change my pitman arm, trackbar new IRO 3.8'' rigth hand drive, new tires, tow new Axle Bearing and Hub Assembly Front Wheel, I have two stering stabilizer, one stering stabilizer in the position as the kevinīs off road anti DW and I still have problems with DW, Please I need your help ..... thanks
Unread 01-14-2010, 04:17 PM   #8
Jean_WJ
Please I need your help is very urgently........
Unread 08-13-2012, 10:45 PM   #9
cmarnik
check tires I did everything to my 2001 than went from 6 ply to a 10 ply tire and it went away.
cmarnik is offline   Reply With Quote
Unread 08-14-2012, 06:07 AM   #10
moparrr07
pitman ares should ONLY be changed in order to parrellelize the trac bar and drag link
get an alignment done, it will need more caster, factory specs will do, get it done by someone who understands jeep suspensions
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline   Reply With Quote
Unread 08-14-2012, 05:46 PM   #11
ratmonkey
R.I.P.
ratmonkey's Avatar
marginal advice(10ply tires are HARD) but the post is 3 years old now.
ratmonkey is offline   Reply With Quote
