At wits end, could use some help! - JeepForum.com
post #1 of 18 Old 12-16-2013, 06:52 PM Thread Starter
highoutput85
Wj At wits end, could use some help!
Ok so here's my problem, I have a 02 grand Cherokee h.o.4.7 with about 138,000 miles on it. I had a rough idle issue so I gave it a tune up (changed plugs, fuel/air filter, both upstream o2 sensors, cleaned throttle body , changed IAC and TPS sensors, oil change, pvc valve , fixed vaccum leaks. Took it out for a spin about 35 miles round trip. Mpgs shot up from about 14 to 22 . Going great until I come to a stop , rpms shoot down to about 300 /400 , wants to shut off but corrects itself and fluctuates but stays on. Take it back home and run a diagnostic on it Po175 and po172 and G-switch malfunction. After a few days later jeep dies on me after driving fine . Start it back up and sputters hard and dies, won't start anymore. Anybody have any ideas? Please and thank you in advance
highoutput85 is offline
post #2 of 18 Old 12-16-2013, 08:07 PM
new2site
Do the key dance to see if any new codes show up on the odometer readout (on/off, on/off on > read odometer)
If you overlook those other codes as maybe an anomaly...it sounds like your CkPS is out. - p0320
On your 4.7 it's located right above your starter.
new2site is offline
post #3 of 18 Old 12-16-2013, 08:24 PM Thread Starter
highoutput85
I pulled out plugs and where a bit fouled , plugs only had about month and a half wear on them, is there a way to check the crank sensor?
post #4 of 18 Old 12-16-2013, 08:36 PM
MuddyWJ
Switch it out. What kind of plugs Did you use? The V8s are very sensitive to their plugs.
MuddyWJ is offline
post #5 of 18 Old 12-16-2013, 08:37 PM
car5car
2002 M-38
car5car is offline
post #6 of 18 Old 12-16-2013, 08:44 PM Thread Starter
highoutput85
I used autolite double platinums
post #7 of 18 Old 12-16-2013, 08:46 PM
MuddyWJ
I believe the OEM are champion coppers. Try those and see what happens. The hard sputter issue I would look to the crank sensor.
MuddyWJ is offline
post #8 of 18 Old 12-16-2013, 09:25 PM Thread Starter
highoutput85
Ok I will check it out this weekend, any input on the G- switch malfunction?
post #9 of 18 Old 12-16-2013, 09:36 PM
MuddyWJ
I don't even know what the G switch is!?!
MuddyWJ is offline
post #10 of 18 Old 12-16-2013, 10:51 PM Thread Starter
highoutput85
I've called 6 local dealerships and looked every online no solutions. Read about it saying it might be a abs acceleration sensor? Any ideas?
post #11 of 18 Old 12-17-2013, 02:29 AM
ADragg
2003 WJ
It's probably not the plugs, but I would definitely replace them with new Chamion Coppers. They're what the 4.7 V8 likes. Do some searching if you want to confirm. It will probably like the cheap Coppers more, but again, that's probably not the actual problem. I'd do some searching and checking on this forum when replacing any part or doing any repair, really, cause the V8 is so finicky and particular about things. It's good to find out what's really recommended.
3.5" lifted '03 Limited Quadra Drive WJ - OME HD coils, Bilstein 5100 shocks, JKS track bar, IRO extended links, OME 10mm spacers, Moog SS, JK Moab wheels w/ 265/70/17 (32") Goodyear Duratracs.
ADragg is offline
post #12 of 18 Old 12-17-2013, 04:49 AM
cde02ltd
I thought the high output 4.7 took platinum plugs?
cde02ltd is offline
post #13 of 18 Old 12-17-2013, 06:04 AM
86cj74.2L
86cj74.2L's Avatar
Those two codes mean your running too rich on both cylinder banks.
Why? Could be a few things. Without a scanner to read live data to verify the engine temp sensor is ok I'd wonder what your fuel pressure is.
It's getting too much fuel on both banks of cylinders. Since its both banks.....the only thing they have in common is the fuel pressure, engine sensors, air cleaner, and exhaust system.
86cj74.2L is offline
post #14 of 18 Old 12-17-2013, 12:48 PM Thread Starter
highoutput85
I replaced the factory o2 sensor (both upstream) to denso sensors , I was that the engine has problems reading them , is that true?
post #15 of 18 Old 12-17-2013, 01:11 PM
86cj74.2L
86cj74.2L's Avatar
You used something other than Bosch. I'd trust them for now and look at why its getting extra fuel.
Fuel pressure
Restricted exhaust
A sensor is going bad and causing the PCM to chose the wrong fuel map. Then the O2 sensor sees a rich condition and the PCM trims back the fuel and when the LTFTs get to -20% fuel trim it gives the running rich codes.
