windows wont go down - JeepForum.com
post #1 of 12 Old 06-27-2013, 09:08 AM Thread Starter
tnp0412
1999 Jeep Grand cherokee windows wont go up
My jeep was working fine yesterday and then this morning my windows wont go up.. my interior lights keep staying on also. none of the windows will go down with their own switch or the master switch.. has anyone had this problem? or can anybody please help me....!
thank you
tnp0412 is offline
post #2 of 12 Old 06-27-2013, 09:11 AM Thread Starter
tnp0412
Wj windows wont go down
my jeep was working fine yesterday and then this morning when i went out the windows wont go up or down, the interior lights stay on, my locks wont work and i cant move my mirrors. can someone please help me... i really need this fixed!!thank you
tnp0412 is offline
post #3 of 12 Old 06-27-2013, 09:18 AM Thread Starter
tnp0412
my windows were working fine yesterday and then i go out today and they wont work... they wont go up or down.. the locks dont work. my mirrors wont move and my interior lights stay on.... help
tnp0412 is offline
post #4 of 12 Old 06-27-2013, 09:52 AM
1999wjlimited
It's a broken ground wire in the drivers door rubber boot.
1999 WJ Limited 4.7 4x4 - 15x8 pro comp soft 8's - 2.5" bb- 31x10.50x15 General grabber at2
1999wjlimited is offline
post #5 of 12 Old 06-27-2013, 10:40 AM
foggybottombob
You should post this in the WJ forum.
foggybottombob is offline
post #6 of 12 Old 06-27-2013, 03:25 PM
Erich_97
Probably a broken ground wire
Erich_97 is offline
post #7 of 12 Old 06-27-2013, 03:51 PM
heitzman
Check inside the drivers side door jamb boot for broken wires.
heitzman is offline
post #8 of 12 Old 06-27-2013, 05:01 PM
DavisI
Try reconnecting the negative terminal on the battery. It's worth a shot and might help. Plus it's free
2002 WJ 4.7
4.5"/3.5" with 32"x10"
DavisI is offline
post #9 of 12 Old 06-27-2013, 11:47 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Mega threads merge from all over the forum!
***Chris***
chris87xj is offline
post #10 of 12 Old 06-28-2013, 03:20 AM
cykaaro
You have now entered pergatory were threads merge into one pile of WTH?
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #11 of 12 Old 06-28-2013, 03:21 AM
cykaaro
... and yes, as said, check the wiring in the boots on the doors. Most like one or more wires are severed or rubbing causing a short.
cykaaro is offline
post #12 of 12 Old 06-28-2013, 05:20 AM
4xTroy
4xTroy's Avatar
I've had this happen many times on my 2002 WJ. When you repair this, put an extra few inches on the lead. Check your other wires for wear and fix those at the same time. It was my 3rd repair before I finally added some extra length.
The 4th time this happened, I was really upset... I pulled the boot off, inspected the wires. I attacked them with a meter, but never could find the problem.
A few weeks later, I got my tax refund and finally broke down to buy a new drivers seat (the lower frame had collapsed). When I pulled my old seat out, I was met with a shower of sparks, as the seat frame had torn up the motor control wires and grounded out.
Once I finished replacing the seat, the windows, mirrors, lights, AC, EVIC, and a couple other things started working again.
Who would have thought that a broken seat could cause so many issues.
4xTroy is offline
cherokee , interior lights stay on , windows
