Windows/Locks not working - JeepForum.com
post #1 of 29 Old 07-29-2013, 07:15 PM Thread Starter
cherokee420
So before I started working on my jeep, everything was working fine.
I had all 4 door panels off to put my aftermarket kenwood speakers in, and I also had my dash out to replace the heater core.
I have double checked wiring plugs to make sure they are connected tightly. Everything else in the jeep is working properly.
Not sure what else to check
cherokee420 is offline
post #2 of 29 Old 07-29-2013, 07:39 PM
4Tom
If the fuses are ok check for broken wires in drivers door boot.
These are the wires going from body to door. The rubber boot will unclip from door by hand usual a visual inspection is enough as its the thicker cables that break.
If they are broken dont just add a crimp connector as there is a lot of flexing of the cables every time door is opened and closed.
Best way to tackel it is to add a extra 9 inches of cable and soldered connections using heat shrink for insulation.
If you remove the body trim in foot well it will give you more room to work. you can pull one side of the broken cable back into foot well solder on a short lenght of cable same gauge as broken cable. Then feed it back through the rubber boot and solder to other end of broken cable at door.
The slack can be pulled back into body.
WJ 2001 3.1TD
Tom
4Tom is offline
post #3 of 29 Old 07-29-2013, 08:11 PM Thread Starter
cherokee420
I have checked a whole bunch of fuses, but none say anything about door locks or windows.
the door locks and windows stopped working after I put the speakers in. they worked fine before.
no broken wires that I have found.
post #4 of 29 Old 07-29-2013, 08:26 PM
4Tom
http://www.wjjeeps.com/fuses.htm
Fuse box
F8 15amp locks
Power distribution panel under hood
12 50amp windows
WJ 2001 3.1TD
Tom
4Tom is offline
post #5 of 29 Old 07-30-2013, 12:07 AM
new2site
If you don't find a burnt fuse...I would re-check the drivers side plug...if that's not fully connected NONE of your windows will work...like what you have happening...
new2site is offline
post #6 of 29 Old 07-30-2013, 10:28 AM Thread Starter
cherokee420
Originally Posted by new2site View Post
If you don't find a burnt fuse...I would re-check the drivers side plug...if that's not fully connected NONE of your windows/locks will work...like what you have happening...
drivers side plug ? do you mean the plug on the door, or the 2 big white plugs beside the foot rest on the left ?
post #7 of 29 Old 07-30-2013, 05:11 PM
4WDlifeform
4WDlifeform's Avatar
Also having somewhat similar issues with my windows/door locks. I have found that when I close my driver door, the windows work. When the door is open, the windows will not work. Its too consistent in that manner that something could be lose. Is that the case with yours?
Not meaning to hyjack the thread, but my power locks are acting up, in that when I lock the doors from driver door, it only locks the driver side doors. If I look from the passenger side, only the passenger side door locks... So confused....
4WDlifeform is online now
post #8 of 29 Old 07-30-2013, 05:50 PM
4Tom
^^ See my post above on broken wire going from body to drivers door. Guarantee (money back ha ha ) you have broken wire.
WJ 2001 3.1TD
Tom
4Tom is offline
post #9 of 29 Old 07-30-2013, 05:57 PM
Thomahawk
Yeah you should know by now 4Tom, if you got a $ every time you helped someone with this issue, you would been crazy Rich by now.
I can see you answer These same topic threads on daily basis, the search function is still not freqvently used, lol, Thumbsup 4Tom
Buildthread
Thomahawk is offline
post #10 of 29 Old 07-30-2013, 07:11 PM
4Tom
I do but no $ yet lol...
know many will waste hours if not days trying to track it down... and end up replacing body modules door switches etc before discovering real issue.
Regret now didn't do a write up with pictures and put it in stickies.
Anyway it kills time while I'm waiting on my diesel buddies to post interesting faults... either their 5 pots are ultra reliable or they too lazy to post. Hope they haven't killed them and run out and bought petrols ha ha..
Good to see your minding yours like a baby.. and you have recover gear on it just like a real jeep should be
Ive given up posting on what biggest tire fits my jeep.
WJ 2001 3.1TD
Tom
4Tom is offline
post #11 of 29 Old 07-30-2013, 08:14 PM
new2site
Originally Posted by cherokee420 View Post
drivers side plug ? do you mean the plug on the door, or ....
Yes ...the main plug inside the door... long white rectangular one...
new2site is offline
post #12 of 29 Old 07-31-2013, 01:00 PM Thread Starter
cherokee420
There is 2 white plugs that are held on with a bolt. I checked all the wires and none are broken
post #13 of 29 Old 07-31-2013, 01:23 PM
new2site
Not sure about those...I'm referring to the "master" connection directly to the window/door lock switch on the inside removable door panel. On my '02 it "slides into/snaps in" master control switch....no bolts.
My point was to make sure this didn't get slightly tugged back (appearing to be connected...but not fully) when you took these panels off when installing speakers. Just get a good grip on it and give it a good push in...you could test some of the windows/locks before you reinstall the panel back on...one hand holding the panel up ..other hand moving the switches..
I have connection circled in white on first picture... second picture is what actual connector looks like (but not as many wires going to it on wj)
new2site is offline
post #14 of 29 Old 08-01-2013, 10:10 PM
new2site
Did you find out the problem?
new2site is offline
post #15 of 29 Old 08-02-2013, 05:41 AM Thread Starter
cherokee420
Well yesterday I started looking for broken wires and only managed to find 1 broken wire. Wired it back together with some spare wire I had, and still nothing.
I also pulled out fuse 12 and put a different fuse in
Still no windows or locks.
