window switch lights - JeepForum.com
post #1 of 5 Old 11-07-2013, 05:20 PM Thread Starter
mdrum93
anyone who has done an interior LED swap ever done the window switch lights to match the dash and such? I cant seem to find much on switching LEDS into anything other than the dash and HVAC but I want to switch EVERY bulb in my WJ eventually.
mdrum93 is offline
post #2 of 5 Old 11-07-2013, 07:29 PM
rdkendrick
2003 WJ
http://www.wjjeeps.com/lamps/lamps.htm#LIGHTLINKS
The Superlumination.com link has a good cross-reference, but I don't recall seeing the door lock/window switch bulb. I ordered the NEOx 3mm for the EVIC, but the 4mm would probably fit better. You will have to solder the heater control and radio bulbs.
Sent from my iPad using my fingers
rdkendrick is offline
post #3 of 5 Old 11-07-2013, 07:50 PM
its-me-B
For the lock and window switches I believe you'd need to disassemble them and solder in new led bulbs. I don't think there's any other way...
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #4 of 5 Old 11-07-2013, 07:58 PM
rdkendrick
2003 WJ
Same bulb as EVIC, but without the base?
post #5 of 5 Old 11-08-2013, 06:42 PM
its-me-B
I don't believe so, I have only taken the seat heater switch apart but those were really small
its-me-B is offline
