Window falling down - JeepForum.com
post #1 of 8 Old 12-12-2013, 08:24 PM Thread Starter
MarkBlair
Window falling down
As I was driving today my passenger window slowly started sliding down by itself. The switch wouldn't work so I tried to pull it up with my hands, when I let it go it completely fell all the way in and won't move, do you think it just fell off the track? I can hear it moving inside the door when I press the switch for it
MarkBlair is offline
post #2 of 8 Old 12-12-2013, 08:50 PM
PERK
you need a new window regulator, common brakeage on a wj. there's a few you tubes on the replacement.
PERK is online now
post #3 of 8 Old 12-12-2013, 09:10 PM Thread Starter
MarkBlair
Alright thanks, that's probably $30-$40 if I'm not mistaken
post #4 of 8 Old 12-12-2013, 09:25 PM
PackLifeNC
Definitely a regulator. I've gone through a few on my wj.
www.packlifenc.com
PackLifeNC is offline
post #5 of 8 Old 12-13-2013, 07:30 AM
cubalz
Uh, no. Dorman ones (these are what you want, not the ebay crap) will run you around $100.00 ea complete from Auto Zone, Adavance Auto etc. I have replaced most of mine in my WJ. Word of advice: Slamming your doors hard is the main culprit of this type of failure. I close mine easy now and have not had any issues since.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #6 of 8 Old 12-13-2013, 08:15 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
99 times out of a hundred, its just the regulator, NOT the motor that needs to be replaced. Local auto parts stores usually only carry ones with the motor included and usually for over $100. Rockauto.com has complete units, with motors for around $60. Or without motors for around $30.
What you can do while you wait for shipping is take the door panel off, take the old regulator out, pull the window up and put a couple bolts in the holes along the top where the panel snaps in. They are at perfect height to hold the window up with out it bouncing around.
~James
ezflip is offline
post #7 of 8 Old 12-13-2013, 09:37 AM
NU_WJ
I was able to fix mine for free (the rear passenger window anyways). There's a fix I found where you use a piece of metal hanger wire to secure the window regulator cable (bc it's the plastic anchor that breaks). It's been working perfectly for over a year now. If money's no issue then go ahead and buy new...but may not be necessary. My 2 cents.
NU_WJ is online now
post #8 of 8 Old 12-13-2013, 09:47 AM
NU_WJ
NU_WJ is online now
