Will 350 chevy engine fit in a wj? - JeepForum.com
post #1 of 10 Old 06-10-2013, 02:13 PM Thread Starter
iwheelinbama
If not what engines are direct bolt on for the 99 wj limited 4.7. Any help will be much appreciated, we just blew my engine and was curious to if there were any engine that are direct bolt on and a 350 would be pretty sweet.
iwheelinbama is offline
post #2 of 10 Old 06-10-2013, 02:20 PM
Jeeples
Jeeples's Avatar
Checks location.....yep.
Anyway, I'm sure it would fit, but unless you're doing an LSx series engine, why? Most older run readily available EFI SBC's make less power than the 4.7, not to mention you will need a standalone EFI and Transmission management system as well.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #3 of 10 Old 06-10-2013, 02:26 PM Thread Starter
iwheelinbama
Interesting.. Would it be possible to put in the H.O? What other modifications would i need to do in order to do that?
post #4 of 10 Old 06-10-2013, 02:32 PM
WJ2000
No, not an chevy , Say yes to an HEMI '' H'EEEMMMIIII ''
2000 WJ 4.0 NEW 4.6 stroker. W/ 4'' Tera Flex Long arm kit, KING 2.5s w/res front,2.5 Kings w/res Rear,Tom wood front drive, 33 x 15s KM2s, Bassett 15'x8 ,fully addjustible Tera flex Track bar, IRO 3link rear, EBC Dippled & sloted front disks, EBC green stuff pads, Iceland off road fender flairs''.
WJ2000 is offline
post #5 of 10 Old 06-10-2013, 02:32 PM
Jeeples
Jeeples's Avatar
Yeah, an HO would be your best option for a drop in HP increase vs. the motor currently in your WJ. I would think at the very least you would need the underhood wiring harness since the HO's have two knock sensors (IIRC) and the PCM.
Jeeples is offline
post #6 of 10 Old 06-10-2013, 02:46 PM Thread Starter
iwheelinbama
How much more is the H.O?
post #7 of 10 Old 06-10-2013, 04:13 PM
lazyWJ
2006 XK Commander
$695.49 more for HO.
This is one of those questions that "if you have to ask..."
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #8 of 10 Old 06-14-2013, 09:13 PM
elcorvino
2003 WJ
A stroked sbc that is carbed would probably triple the numbers of a 4.7HO. I've seen big number hemi motors, so that's a different story.
elcorvino is offline
post #9 of 10 Old 06-15-2013, 12:56 AM
Darnice
Hemis won't fit without frame modification.
Darnice is offline
post #10 of 10 Old 06-15-2013, 07:37 AM
narnwv
narnwv's Avatar
A H.O. Will require a new PCM and wiring harness. A Hemi requires major frame mods, and a lift, and hood modification. Any other v8 would require a nee transmission, as well as all new wiring, and none of the gauges would work.
Typing on phones sucks.
~Aaron
narnwv is offline
