Will 255/70R16 fit stock WJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Will 255/70R16 fit stock WJ?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-25-2014, 01:50 PM   #1
FastSUV
I have 225/75 on my '04 and when I get new tires, I want something that looks better and wider...I put 245/70's on my '01 WJ and they look good but I am wondering if the 255's will also fit?
No lift planned at this time because that is what my ZJ is for, but eventually I might do a BB on the '04...for now though, let's assume no lift because that is what it is.
ZJ - 5.9 Limited
WJ - 4.0 Laredo
WJ - 4.7 Laredo
WJ - 4.7 H.O. Freedom
FastSUV is offline   Reply With Quote
Unread 04-25-2014, 02:04 PM   #2
Range07
2003 WJ
I *think* with the 255/70, you would be alright for the most part, but probably rub some when turning or braking (depending on quality of suspension I suppose)
Im rolling on 245/70s completely stock, and they have absolutely no tire rub, though when turned to lock, there isnt much extra room
I had the 225/75 on there, and I agree, they gotta go the 245 is noticeably wider than the wheel its mounted on (16x7 silverblade for me), and stands out a lot more than that 225 did on the same wheel.
Range07 is offline   Reply With Quote
Unread 04-25-2014, 02:39 PM   #3
WJ2121
Just got 255/70/26 GY Wrangler Duratracs on 16x8 wheels. I have a 2" BB. . The rear is no problem, The front rubs when I turn the wheel to the right. Only happens when I try to turn the wheel all the way like pulling in and out of tight parking spots. Its very minimal rub I might just deal with it and not cut the bumper. So I'm not sure about stock but you might get away with it or have to trim.
WJ2121 is offline   Reply With Quote
Unread 04-25-2014, 02:46 PM   #4
VestaviaPirate
Originally Posted by FastSUV View Post
I have 225/75 on my '04 and when I get new tires, I want something that looks better and wider...I put 245/75's on my '01 WJ and they look good but I am wondering if the 255's will also fit?
Is it a Laredo? I assume with the 16" wheels? That makes it a 30.5" tire. Assuming I'm right in you wheels, that will fit, JUST barely.
I put on some 245/70's (but on 17" wheels), they are also 30.5" tires. They fit with a pretty extreme tread pattern. I have some very minor (size of a quarter in the splash guards) rubbing, but that should subside soon.
I would imagine your proposal would be similar to what I did, but ymmv.
VestaviaPirate is offline   Reply With Quote
Unread 04-25-2014, 05:10 PM   #5
FastSUV
well I'll have to think about it...the 245/70 looks pretty good on the '01 but I know some people do the 255/70 on ZJ's that are stock and I think they look awesome...decisions, decisions
ZJ - 5.9 Limited
WJ - 4.0 Laredo
WJ - 4.7 Laredo
Unread 04-26-2014, 07:35 AM   #6
Super6XJ
they should fit, had em on older wj and stock suspension, no rubbing,
Your Welcome
Super6XJ is offline   Reply With Quote
