Wierd Wobble - Page 2 - JeepForum.com
post #16 of 23 Old 07-13-2013, 02:34 PM Thread Starter
Jeepin99WJ
The best way to explain it is that it feels like its vibrating from the front and the steering wheel shakes a lot.
Jeepin99WJ is offline
post #17 of 23 Old 07-13-2013, 02:55 PM
ChrisHager
Administrator
ChrisHager's Avatar
By steering wheel shakes, do you mean it vibrates or shakes so much that depending on who's driving, they may not be able to hold onto it as well as the wheels themselves are shaking to a point where you think you could lose control?
There's a biiiig difference between the two with completely different repairs.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #18 of 23 Old 07-13-2013, 03:05 PM Thread Starter
Jeepin99WJ
No it's not crazy. It is a little unsettling when on the highway but I don't feel like I'm completely out of control. And it seems to only happen from like 50-60 mph.
post #19 of 23 Old 07-13-2013, 03:11 PM
ChrisHager
Administrator
ChrisHager's Avatar
Check your tie rod ends - do a dry steering test and see if there is any slack in any of them. Balancing your tires wouldn't hurt either.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #20 of 23 Old 07-13-2013, 03:24 PM
js12278
Vibration, shakes, wobble.... I am tempted to say ..perfectly normal. lol. You are going to have to rule out any of the suggestions made here.
js12278 is offline
post #21 of 23 Old 07-15-2013, 07:51 AM
wyattwj123
I just replaced my rotors and that seems to be the problem with mine and I had the same exact symptoms as you! If you need them then try doing that mine would only shake between 50-60 mph
wyattwj123 is offline
post #22 of 23 Old 07-15-2013, 06:52 PM Thread Starter
Jeepin99WJ
Did it shake even when you weren't applying your foot on the brake?
post #23 of 23 Old 07-16-2013, 07:48 AM
wyattwj123
Yea I didn't even press the brakes!
