Wierd Wobble - JeepForum.com
post #1 of 23 Old 06-27-2013, 12:25 PM Thread Starter
Jeepin99WJ
Wierd Wobble
When I'm driving at highway speeds and have to hit the brakes for traffic, like when someone cuts me off, it wobbles pretty bad, the steering wheel that is. I'll let go of the brake quick and re-apply the brakes and then it seems to be fine. Any ideas???
Jeepin99WJ is offline
post #2 of 23 Old 06-27-2013, 12:41 PM
ChrisHager
Administrator
ChrisHager's Avatar
A warped rotor could vibrations. If you have worn suspension parts like TRE's, braking could also cause these parts to show their wear causing a wobble similar to the beginning stages of DW. My wife's TJ is just starting to do this.
Now, the fact that you can reapply the brakes and the wobble stops tells me something has worn out a bit. Start by checking your TRE's.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 23 Old 06-27-2013, 12:54 PM Thread Starter
Jeepin99WJ
What is TRE? Sorry I'm a noob. Lol
post #4 of 23 Old 06-27-2013, 01:01 PM
ChrisHager
Administrator
ChrisHager's Avatar
Tie Rod End. You'll have 4 you want to look at. Test by having someone quickly turn the wheel back and forth while you're underneath checking out the TRE's. You may need to place your hand on each one to feel for any looseness. While you're under there, note any other possible loose parts.
So you know what you're looking for...
New VS Old
Passenger Side
Drivers Side
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 23 Old 06-27-2013, 01:06 PM Thread Starter
Jeepin99WJ
If they are bad are those easy to DIY or should I just have a shop look at it?
post #6 of 23 Old 06-27-2013, 01:10 PM
ChrisHager
Administrator
ChrisHager's Avatar
Sometimes they can be fairly easy and sometimes not. You have to remove a cotter pin and a castle nut for each TRE. Once these are removed, if the TRE itself is stubborn and 'stuck' in, a good whack with a hammer helps coax them out. Once out, removing them from the adjusting sleeves can be a pain in the butt. I ended up buying MOOG brand TRE's (all 4) and both adjusting sleeves. This made the job much easier.
Once removed and replaced, you'll need an alignment.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #7 of 23 Old 06-28-2013, 04:50 PM
JeepDrew_94
Im having the same exact problem. I have a 2000 WJ stock with 110,000 miles. Having a squeeking problem coming from the front driver also when driving over bumpy parts of the road. Any Ideas?
JeepDrew_94 is offline
post #8 of 23 Old 06-29-2013, 11:29 AM
ChrisHager
Administrator
ChrisHager's Avatar
Sounds like a bushing has gone dry or bad. Check your control arms and track bar.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #9 of 23 Old 07-12-2013, 03:38 PM Thread Starter
Jeepin99WJ
At 50-60 mph when I'm either speeding up to get on the highway or slowing down to get off the highway the wobble happens and my steering wheel wobbles pretty bad. My foot wasn't even on the gas or the brake when it was wobbling and it stopped happening as soon as I was at 45 mph. The last time I was at a mechanic they told me they heard "growling" in the front diff. and my cv boots have been torn for awhile on the front axles. I don't know if that's related but does anyone have any ideas?
post #10 of 23 Old 07-12-2013, 06:06 PM Thread Starter
Jeepin99WJ
Help anyone...
post #11 of 23 Old 07-13-2013, 11:16 AM Thread Starter
Jeepin99WJ
Bump
post #12 of 23 Old 07-13-2013, 11:30 AM
wyattwj123
Same exact thing is happening to me I'd loves know
wyattwj123 is offline
post #13 of 23 Old 07-13-2013, 11:43 AM
skain8
skain8's Avatar
How old/good are your tires?
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #14 of 23 Old 07-13-2013, 11:56 AM Thread Starter
Jeepin99WJ
Tires are practically brand new
post #15 of 23 Old 07-13-2013, 01:57 PM
ChrisHager
Administrator
ChrisHager's Avatar
Is it a vibration like a wheel is out of balance kind of thing or is it a wobble in the axle?
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
