Wierd Infinity Stereo Problem - JeepForum.com
post #1 of 8 Old 06-11-2013, 01:38 PM Thread Starter
rudes
I have a 2002 with stock Infinity sound system that has the CD/cassette head unit, amp under back seat and speakers in the dash and 4 doors. The front left dash speaker has an annoying buzzing sound coming from it, almost like it's blown. The right side is fine. I swap left and right speakers and the noise is still on the left front side. I swap amps and the noise is still on the left front side. I swap head unit and the noise is still there. Only thing left is the wiring. What's up??
rudes is offline
post #2 of 8 Old 06-11-2013, 03:35 PM
its-me-B
did you check the wires from the headunit to make sure everything is intact? same for the wires by the speaker also... when I swapped headunits I had one speaker wire on the factory harness come loose and cause a buzzing from only one speaker. I forced the wire back into its place and glued it in so it wouldn't come out again.
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #3 of 8 Old 06-11-2013, 08:07 PM
mikeyc1821
i have the same issue, it also seems that i have no bass untill the stereo "warms" up then the buzzing goes away and everything is a lot louder.. anythoughts
mikeyc1821 is offline
post #4 of 8 Old 06-11-2013, 09:58 PM
Thegdog
Its a buzz right? Not a rattling? I thought that mine was blown at first, but I realized it was just the plastic on the dash ratting. Could be some kind of EMI. Do you have any other equipment in the car that could cause that?
Thegdog is offline
post #5 of 8 Old 06-12-2013, 06:05 AM Thread Starter
rudes
The sound is exactly what a speaker with a damaged voice coil would sound like. It works but has that annoying rattle buzz type sound that fluctuates with music and voice. I will check all my din connections on amp and head unit today.
rudes is offline
post #6 of 8 Old 06-12-2013, 06:34 PM
mikeyc1821
kind of sounds like a fly stuck in the screen door.
post #7 of 8 Old 06-14-2013, 09:34 AM
Thegdog
Have to tried sending audio to amp directly? Bypassing the head?
Thegdog is offline
post #8 of 8 Old 06-15-2013, 11:04 AM Thread Starter
rudes
Thanks for the replies guys! I sprayed all DIN connectors, head unit and amp. That did it.
rudes is offline
