Why pull front driveshaft for highway driving? - JeepForum.com
 4Likes
  • 1 Post By ChrisHager
  • 1 Post By grayWJ4x4
  • 2 Post By ChrisHager
post #1 of 15 Old 08-18-2017, 08:34 AM Thread Starter
dnt6972
My son will be driving his 1999 Grand Cherokee from CO to WI next week and someone suggested we pull the front driveshaft and run it in 2WD on the highway. Why?
dnt6972 is offline
post #2 of 15 Old 08-18-2017, 09:12 AM
Squarecat
Squarecat's Avatar
1993 XJ Cherokee
MPG savings.
But while it sounds reasonable in theory, I'd hesitate to call it prudent. Physically removing a part that is designed to be there could introduce other issues that will cost more than the modest gas savings. Especially on an older vehicle.
Sent from my iPhone using Tapatalk
Squarecat is offline
post #3 of 15 Old 08-18-2017, 09:22 AM
ChrisHager
Administrator
ChrisHager's Avatar
If I were that concerned with MPG, I would look into borrowing a car.
MWF likes this.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 15 Old 08-18-2017, 09:42 AM
Squarecat
Squarecat's Avatar
1993 XJ Cherokee
^ this is good advice ^
post #5 of 15 Old 08-18-2017, 09:48 AM Thread Starter
dnt6972
That's what I thought. The guy said it would "destroy" the front end. I have a hard time believing that one but thought I would ask around.
dnt6972 is offline
post #6 of 15 Old 08-18-2017, 09:51 AM
ChrisHager
Administrator
ChrisHager's Avatar
Wait... He told you you SHOULD remove the front driveshaft for a long drive to PREVENT the front end from being destroyed?
I wouldn't let him maintain any of your vehicles...
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #7 of 15 Old 08-18-2017, 09:52 AM
grayWJ4x4
Removing the front drive shaft has zero affect on the drivetrain wear. You can drive without it forever and nothing will happen.
Having said that you also get pretty much zero gas savings.
I had mine off for the entire summer because I need it to get balanced.
And I did at least a dozen 300 mile trips with it off.
grayWJ4x4 is offline
post #8 of 15 Old 08-18-2017, 10:06 AM
TheDashingRogue
2003 WJ
Correct me if I'm wrong, but I was under the impression that 4x4 WJs were designed to run 100% power to the rear wheels by default until slippage starts to occur, and then the Quadra-Trac/Quadra Drive system works it's magic to distribute that power where needed.
I don't know if removing the front drive shaft would harm the engine or not as I've never tried it myself.
However I can't imagine the MPG gains would be terribly significant. The only thing I see it reducing on 100% highway driving is drivetrain friction caused by the moving parts freewheeling while disengaged. But you'd still get some even then...
Again, I could be totally wrong here. Please do correct me if I am.
Sent from the SR-2 Normandy's Quantum Entanglement Communicator using Tapatalk
"Not all those who wander are lost..."
TheDashingRogue is offline
post #9 of 15 Old 08-18-2017, 10:57 AM
ChrisHager
Administrator
ChrisHager's Avatar
Correct.
Engine wear is not relative to driveshaft number.
Since WJs don't have lockout hubs, all of the axle parts would still be spinning. The only reduction in friction by removing the driveshaft would be the loss of driveshaft movement itself.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #10 of 15 Old 08-18-2017, 11:02 AM
TheDashingRogue
2003 WJ
Correct.
Awesome! Glad I got that right, and that I wasn't just repeating nonsense.
And about the friction, I figured as much. That's why I didn't think there'd really be any significant difference with the MPGs if you remove the driveshaft or not.
post #11 of 15 Old 08-18-2017, 05:03 PM
Planetcat
2010 WK
"Someone" is an idiot. I think if you have Quadratrac II or Quadradrive, the nv247 transfer case (i.e. progressive coupler) will detect different wheel speeds between front and rear when the front DS is disconnected, thereby engaging 4wd and probably not for the better. If you have SelectTrac (nv242), then I guess you could run it in 2wd and disconnect the front DS, but I'm not sure why. You guys can correct me on the nv247 thing, if I'm wrong.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #12 of 15 Old 08-18-2017, 05:15 PM
grayWJ4x4
247 or 242. Makes no difference. You can remove the front DS and drive forever and you'll be just fine.
You just won't have a 4WD Jeep.
99SK04GTX likes this.
post #13 of 15 Old 08-19-2017, 08:31 AM
ChrisHager
Administrator
ChrisHager's Avatar
I'm sad that this exists from the factory.
grayWJ4x4 and TheDashingRogue like this.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #14 of 15 Old 08-21-2017, 03:45 PM
SeveSeven
the viscous coupler in the tcase doesnt care that its locked up with no load. key being no load. it will spin the output but the actual torque transfer is virtually nothing so the fluid wont get destroyed. the driveshaft is like nothing in energy to spin, if you could unlock the hubs thats a different story because you are dealing with the ring and pinion friction. i wouldnt bother, literally might save 5 bucks over a thousand miles. youre better served checking alignment and tire pressures lol.
SeveSeven is offline
post #15 of 15 Old 08-28-2017, 08:06 PM
Monzsta
I pulled mine due to a joint going bad. Didn't notice any difference in mpg, and I lost my holeshot superpower in the rain. Drifting on/off ramps was fun, though. It went back in when I got a repair kit.
Monzsta is offline
