Why I had no heat, pics - JeepForum.com
 1Likes
  • 1 Post By Cobra Jeep
post #1 of 3 Old 12-13-2013, 05:58 PM Thread Starter
Cobra Jeep
Well I tried several times but could never get my heater core to flow good. Tried a water hose, compressed air, even a steam cleaner pressure washer with no luck.
So today my dash had a out of vehicle experiance. I replced the heater core, evap core (figured I might as well since I was already in there and also replaced the recirc door/housing and the door actuators.
After all was said and done, I now have heat, and I wanted to see what the old heater core looked like inside. So heres the pic:
I also found the evap core was pretty nasty and partly stopped up with debris. Pic:
Just figured I would share the pics so people could see. If you tried flushing your heater core with no luck, I bet it probably looks like mine.
Dan_in_MN likes this.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #2 of 3 Old 12-13-2013, 06:08 PM
mycreativename
That's nasty as can be! Was it green coolant in there or something?
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 3 Old 12-13-2013, 06:09 PM
glassyjeep
1973 CJ5
Did that job summer of 2012 on my XJ. What fun. Had the heater box back in and dash in place only to find that the blend door was bound up. Pulled it back out and fixed it. What fun. Second time I was much faster!
,[____l,
_-o||||o-_
()_)ŻŻ )_)
Synthetic Oil For What Moves You!
glassyjeep is offline
