Why can't I polish my headlights correctly?! - JeepForum.com
post #1 of 34 Old 09-21-2013, 12:43 PM Thread Starter
jbaldry
Having some trouble here, and it's really starting to piss me off. I have spent hours sanding my headlights from 600 to 1000 to 2000 to 3000 then compound, polish, then micro polish. And don't get me wrong they are certainly shiny! But when you put a light through it you can see scratches! Which frankly I didn't even have before. All I had was minor hazing and some rock chips. What am I missing here? Should I just go buy a headlight kit where you attach sanding pads to a drill? I'm retrofitting my headlights (I'll post that soon) and I want to my lens or covers to look brand new.
Thanks for the help, Jake
2000 Jeep Grand Cherokee Limited, Quadradrive, 4.7 V8
Living life mod by mod
jbaldry is offline
post #2 of 34 Old 09-21-2013, 01:52 PM
Olese
If you're going all the way down to 2 & 3000 grit, you're rubbing compound might be too aggressive, what are you using for compound, polish, and micro polish? Machine or hand? Mine had a light hazing as well and I used 3m 39002 compound by hand and it did a great job.
Olese is offline
post #3 of 34 Old 09-21-2013, 02:15 PM Thread Starter
jbaldry
I'm using Chemical Guys V34 V36 then 38 and I did it first by machine Orbital then I switched to hand because it didn't seem aggressive enough. It was as if my scratched were STILL from the 600 grit
jbaldry is offline
post #4 of 34 Old 09-21-2013, 02:22 PM
Knightrider9827
I used 1500, 2500, 4000 then 5000 grit. Then meguiars plastic cleaner. Still have scratches, but didn't sand that long with the finer grit.
Knightrider9827 is offline
post #5 of 34 Old 09-21-2013, 02:51 PM
Olese
Well, I don't want to sound like I'm stating the obvious but keep in mind that you have to get ALL of the 2000 grit scratches out with the 3000 and ALL of the 1000 scratches out with the 2000 and ALL of the 600 grit scratches out with the 1000. If you don't get the 600 grit scratches out with the 1000, it would take forever to get them out with the 2000 or the 3000.
If they were only lightly hazed, the 600 might have been too aggressive to begin with but will still sand out with enough work.
Olese is offline
post #6 of 34 Old 09-21-2013, 05:31 PM
WJChris
WJChris's Avatar
also, just to be sure, make sure you are using at least water when sanding, best to add a drop or two of car wash soap.
I use a power ball with plastic X on a drill after 600, 1500 and polished like the day they were new.
WJChris is offline
post #7 of 34 Old 09-21-2013, 05:39 PM
StormChaserTim
Starting with 600?!?!?
Start at 1500, then 2000, then 3000.
I use mag wheel polish to polish back out, works like a CHAMP.
In your case, I'd go over them again with 1500, 2000, and 3000, and make sure you are wetsanding. Keep everything as wet as possible. That will keep the surface cool, and lessen the risk of heat-blistering.
Tim
1995 Jeep Grand Cherokee Laredo, 4.0L 2WD, 355,000 miles.
StormChaserTim is offline
post #8 of 34 Old 09-21-2013, 08:43 PM Thread Starter
jbaldry
Alright looks like I'm going to have to grab some 800 to take out the 600 then 1000, 1200, maybe 1500 if I can find it, 2000, 3000, then polish
jbaldry is offline
post #9 of 34 Old 09-21-2013, 08:44 PM Thread Starter
jbaldry
Tim
What do you use to apply the mag wheel polish?
jbaldry is offline
post #10 of 34 Old 09-21-2013, 09:19 PM
coloradowjowner
What does everyone do after they spend the time polishing; to keep the lenses shiny and new? Clear coat? Some 3M clear bra product? Weekly waxing? I spent a lot of time polishing my headlight lenses, and within about 3 months they looked nearly as bad as before the polishing. Colorado is pretty brutal on plastic parts.
coloradowjowner is offline
post #11 of 34 Old 09-22-2013, 09:13 AM
imaguy3
I used Sylvania's headlight kit.. came with the sand paper, rubbing compound, and then a polymer liquid which you put on at the end that fills all the scratches and adds back the UV protectant layer you sanded off, to prevent rehazing.
Colorado is no worse than AZ trust me on that... b/t the intense sun and sand blasting wind... My last windshield looked like confetti from all the sand etching.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #12 of 34 Old 09-22-2013, 09:56 AM
3Dog
3Dog's Avatar
^^This. You can even find kits with the film custom-cut to fit your lens. It applies like window tint. Used it on mine after polishing the lenses, and they look perfectly clear many months later. On other vehicles, I have had years of good results with the pre-cut vinyl film. I think I have been buying my kits from autoanything,com.
3Dog
2015 WK2 Overland Hemi ORA II
2000 WJ Limited 4.7L
(IRO 3" Lift, Bilstein 5100s, 3/4" KOR front spring spacers, IRO adj. track bar, stock Silverblade rims in matte black powdercoat, 245/75/16 Goodyear Duratracs, Akebono caliper upgrade, OE armrest cracks...)
3Dog is offline
post #13 of 34 Old 09-22-2013, 12:44 PM Thread Starter
jbaldry
Ok main problem: I have polished and everything and still have scratches. Do I go back and sand again but with more steps (like 800 and 1500) or do I find something that supposedly fills the scratches (like mag wheel polish)? Also has anyone else besides that one guy tried mag wheel polish, and would it work for my problem?
jbaldry is offline
post #14 of 34 Old 09-22-2013, 02:00 PM
StormChaserTim
I keep fresh applicator pads around. If you don't have any, a folded, damp washcloth works fine.
Tim
post #15 of 34 Old 09-22-2013, 02:11 PM
StormChaserTim
Hang on a second. The idea here is to cut the outer layer of the plastic, removing the haze, then progressively sanding to remove the scratches. It's exactly the same as paintwork. Mag wheel polish won't fill anything in. What it is, is a super fine abrasive. Fact is, toothpaste would (theoretically) work. The reason you still have scratches is because they weren't fully sanded out by the next finer grit.
Think of it another way:
Coarse (600 grit)
Medium (1000 grit)
Medium Fine (1500 grit)
Fine (2000 grit)
Super Fine (3000 grit)
Ultra Fine (Mag Wheel Polish)
Tim
