Whose done it! - JeepForum.com
post #1 of 7 Old 05-21-2013, 10:18 PM Thread Starter
Roger005
Whose done it!
I want to hook up a trans temp gauge. Whose done it and what kind of details can you provide? Thank you!
Roger005 is offline
post #2 of 7 Old 05-22-2013, 05:55 AM
wvracer821
wvracer821's Avatar
the PML trans pan has a bung already in it for the sending unit. thats probably the easiest way.
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #3 of 7 Old 05-22-2013, 06:49 AM
ZeJokee
I put on int my ZJ and just place a T inline before and after the cooler to see my before and after temps. Ran the sensor from the T to the gauge in the cab. They are glow shift gauges which I have be extremely happy with. I did this while installing a new transmission so I had plenty of room to work. Might be a little harder on the WJ.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #4 of 7 Old 05-22-2013, 07:45 AM Thread Starter
Roger005
Ok. What kind of connections did you have to make for the power and light?
Roger005 is offline
post #5 of 7 Old 05-22-2013, 10:50 AM
Merc1973
I have seen a WJ with a gauge pod (3) on the a-pillar and that looked pretty cool.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #6 of 7 Old 07-23-2013, 02:57 PM
Stimmel
I want to do this as well any updates or links?
Stimmel is offline
post #7 of 7 Old 07-23-2013, 05:30 PM
Double E
Double E's Avatar
Doesn't the Scangauge unit allow you to monitor the trans temp? Sute would be a lot easier than installing, wiring and risking leaks from an added in unit.
http://www.scangauge.com/products/scangaugeii/
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
