-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   Whose done it! (http://www.jeepforum.com/forum/f310/whose-done-1526635/)
Roger005 05-21-2013 11:18 PM
Whose done it!
I want to hook up a trans temp gauge. Whose done it and what kind of details can you provide? Thank you!
wvracer821 05-22-2013 06:55 AM
the PML trans pan has a bung already in it for the sending unit. thats probably the easiest way.
ZeJokee 05-22-2013 07:49 AM
I put on int my ZJ and just place a T inline before and after the cooler to see my before and after temps. Ran the sensor from the T to the gauge in the cab. They are glow shift gauges which I have be extremely happy with. I did this while installing a new transmission so I had plenty of room to work. Might be a little harder on the WJ.
Roger005 05-22-2013 08:45 AM
Ok. What kind of connections did you have to make for the power and light?
Merc1973 05-22-2013 11:50 AM
I have seen a WJ with a gauge pod (3) on the a-pillar and that looked pretty cool.
Stimmel 07-23-2013 03:57 PM
I want to do this as well any updates or links?
Double E 07-23-2013 06:30 PM
Doesn't the Scangauge unit allow you to monitor the trans temp? Sute would be a lot easier than installing, wiring and risking leaks from an added in unit.
http://www.scangauge.com/products/scangaugeii/
The time now is 11:01 PM.
