Who replaced top axle bushing with johnny joint? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Who replaced top axle bushing with johnny joint?
Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-16-2010, 09:32 AM   #1
crashcraddock
Someone had a pic of a fix for the front axle bushing that is a pain to replace. Instead of using another rubber bushing they pressed in a johnny joint or something similar. I'm looking for that thread again and couldn't find it...any help?
crashcraddock is offline   Reply With Quote
Unread 01-16-2010, 05:06 PM   #2
Technohead
Old school
Technohead's Avatar
LSRGreg (pretty sure that was his user name).
Technohead is offline   Reply With Quote
Unread 01-16-2010, 05:28 PM   #3
StrokedWJ
There have been several people that have swapped to the JJ. Greg was one of them. I plan to put it in mine too.
Here's the joint. This is the one with the 1/2" bolt. They also make one with a smaller 7/16" bolt too.
Currie Enterprises CJ Axle Parts
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Click this -->Think you can beat me?
StrokedWJ is offline   Reply With Quote
Unread 01-16-2010, 06:02 PM   #4
Chadicus
tsconver did it. He has pics on the last page of his build thread.
2004 Overland 4.7L HO 4" Teraflex coils, IRO front long arms and rear adj control arms, 32" Goodyear Duratracs
1975 CJ5 Glass tub, AMC 304, Holley TA 470, D.U.I. distributer, 33" Goodyear MTRs
Chadicus is offline   Reply With Quote
Unread 01-16-2010, 06:16 PM   #5
crashcraddock
Thanks guys, I think this will work well with the IRO front long arm kit.
Unread 04-23-2010, 12:45 PM   #6
crashcraddock
For a stock replacement do I need the 7/16" JJ or the 1/2"?
Unread 04-26-2010, 09:38 AM   #7
crashcraddock
bump for the info, I'm assuming 7/16", but you know what happens when you assume...
Unread 04-26-2010, 10:03 AM   #8
StrokedWJ
The 7/16's is the stock size. You can step up to the 1/2" but you'll just have to drill out hole in the upper arm a little bit. Piece of cake if you have one of the step drill bits...
I put the 1/2" version in my UCA mount when I did the front 3-link. I used a ball joint press borrowed from Autozone and it worked very well.
Unread 04-26-2010, 10:57 AM   #9
crashcraddock
Thanks, that's what I was thinking (ball joint press), I guess it only makes sence to step up to the 1/2" then. I'm going to use the JJ on the drivers' side and a new rubber on the passengers' side until I can get the IRO front long arm kit.
Unread 04-26-2010, 12:59 PM   #10
StrokedWJ
Yeah, if you're planning to go with the IRO front long arms (which only use 1 upper) I would highly recommend stepping up to the 1/2 bolt size.
Unread 10-27-2011, 08:58 PM   #11
jusjammmin
Old thread but do the 1/2" bolts work with the caster brackets on the Iro long arms?
jusjammmin is offline   Reply With Quote
